Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
The round filter does not turn and spews dust on both my new models
  • 3,037 Answers
You need to open up the vacuum, take out the filter and see why it won't spin. If something is stuck, free it. It may just need a good cleaning. If you need to lubricate it at all, do so, make sure it spins freely by hand before running the vacuum again. Let me know how this goes.
Benjamin
Posted on Jul 15, 2009
    Genius:
  • 1,847 Answers
The filter is run by vaccum. Take the filter out and there is a passage way in there that could be blocked. If I rememer correctly there is a screen in there. If that dont help then there is a spring hooked to a lever underneath so when you lay the back down it engages caccum to the rollers. It could be that this is stuck and not moving.
Try moving it by hand with the scrubber running.
Thanks
K
Posted on Jul 02, 2009
Do I remove the foam filter when using as a wet vacuum/
No, just paper filter or round cartridge, whatever is on there. Foam only for wet vac.
Jul 23, 2011 | Black & Decker UV200 Wet/Dry Vacuum
When using the attachments dirt and dust spew from the wand tube on the base unless I tilt the vacuum.
thats because your brushroll is still rotating when you use your attachments throwing material from the floor out the wand tube. not much you can do about it on that model.
Jan 01, 2010 | Panasonic MC-V5227 Bagged Upright Vacuum
Vaccum is spewing dust when I try to use it
It sounds like the motor is coated with find dust that has collected on it for months. The motor needs to be serviced and cleaned in the process.
Nov 28, 2009 | Eureka Boss 7601 Bagged Upright Vacuum
Hepa filter stopped on Hoover Windtunnel 2 Model #U8361-900
This has a simple solution IF you have a air compressor with a high pressure nozzle. Outside the house, first remove the Dust bin completely and lay the unit down with the dust bin area up. now start blowing the nozzle at the hepa filter, Alot of dust will come out. Now start to rotate the filter while blowing the dust out. The filter will move one way easier, When there is no more dust reinstall the dustbin and check the suction and the rotation of the filter.
Tony
Nov 17, 2009 | Vacuums
On the back of the shop vac there's a hole...what is supposed to go in there...i turn it on and dust blows out of it like crazy
should have a exhaust filter in the hole. it is round and 5-6 inches long with a type of filter on the end.
Oct 22, 2009 | Shop Vac Shop-Vac 905-65-00 1-1/4" by 8...
Hayden SuperVac central vacuum making an unbelievably loud noise.
Stop using the vac. Remove the filter and clean thoroughly, inspecting for damage. If the vac is spiting out bits off fuzz or lint it may need the motor cleaned and serviced as dirt has leaked past the filter. If it is spewing black, not gray this is carbon dust from the motor brushes. If the noise is scratchy or growling this is a sign of a motor problem as well.
The muffler unless it is a hepa filter/muffler combination is NOT designed to catch dust.
Exhaust dust is a sign of dust leaking through the motor which indicates future moor problems.
HINT, if the guy who installed the muffler didn't secure it right he is probably not a good choice as a service tech either. The muffler is normally clamped or secured in place with a small screw so it can be removed in the event of service.
Jun 14, 2009 | Hayden Industries SuperVac 3600 Central...
Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Mar 06, 2009 | Vacuums
Dust in drum
well should be some movement this indicates air flow, machine prob has small clogg in it some where of filters are clogged, yes they do have filters, despite dyson claims.
Mar 26, 2008 | Dyson DC14 All floors Bagless Upright...
Filter Queen Assembly
On the rubber piece, there is a groove on the inside edge for the screen first, then the filter. Just have to work them into that slot. Then put over the bottom housing. The round paper filter is put on over the tank, then the top unit sits on that. These filters will keep dust out of the motor and head asm.
Mar 18, 2008 | Vacuums
Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
Nov 04, 2007 | Electrolux EL7055A Bagless Canister Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
56 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
