Question about GE WJSR4160DWW Top Load Washer
Washer drain problem
I have a new GE washer. When it drains it overflows the standpipe. Someone suggested restricting the flow of water from the drain hose with a brass nipple. How do I do this and what size do I need?
    President:
  • 3,113 Answers
You have no problem with the washer, your problem is the pipes have a build up in the that is restricting the outflow of the water. This happened to me and I replaced the pipes.
Posted on Jul 02, 2009
Maytag centennial washer says 2 drain is that inside or outside diameter.my washer not drain well - overflows standpipe.
if the standpipe is overflowing then the standpipe is clogged and you have to snake the line so the water will go down the pipe,it's not the washer
Oct 06, 2017 | Maytag Washing Machines
Adora washer has given several years of trouble-free service. Lately, water overflows the drain standpipe and flows on to the floor. Machine washes, spins and rinses just fine - the overflowing is the only...
  1. If the drain water is overflowing the standpipe then you have a problem with the house drain not the washer.You need to clean out the house drain or call aplumber to do it for you.
Jun 17, 2011 | GE WSXH208A Front Load Washer
I have an electrolux front loading washing machine it is leaking water at the bottom and produces chunks of melted plastic during the cycle
Hello. If water is leaking from your washer, check the list below:
  • Is the drain clogged? If you have a clogged drain, it will need to be cleaned – contact a local plumber if necessary.
  • Is the drain hose restricted, or out of the standpipe? If the drain hose is out of the standpipe, you’ll need to secure it. You can do this by bending the end to form a hook, placing the hooked end into the standpipe, and tying the hose to the standpipe or a faucet with a cable tie (one was supplied with the washer), strong filament tape, or duct tape.
  • Are the fill hose connections loose at the faucet or washer? Check them and tighten the hose connections. If they’re loose, you might need to install or replace the rubber sealing washers.
  • Are you using a high-sudsing detergent or is your water soft? Using a high-sudsing detergent, or using too much detergent in soft water, can cause suds to overflow the washer. This may seem like a leak if the suds flow or drip onto the floor. Use a low-sudsing detergent and reduce the amount of detergent you use if your water is soft.
Apr 22, 2010 | HP DVD DRIVE DVD Drive
Ge FRONT LOADER WASHING MACHINE DRAINS TOO FAST AND IT OVERFLOWS OUT OF THE DRAIN PIPE ONTO THE FLOOR. IT HAS 1 5/8" DIAMETER DRAIN PIPE. SOLUTIONS???
Yes, the new front loaders do drain much faster...I find that you need to have a 2" drain for them to work properly without over flowing the standpipe.
Now, what can you do??
You can add on to the standpipe and get it up higher, this will do two things... the higher lift will slow down the pump a bit, but will make it work harder and possibly fail quicker...the higher stadpipe will give you a bit more reserve space for the water to collect and then flow down and catchup after the intial burst of flow from the pump. The higher pipe will also create a bit more pressure to push the water down the pipe.
The next and better fix would be to install a bigger standpipe and trap. Go right back the the main line and run a new 2" line and trap to the washer.
I assume that you checked the existing pipe and trap for blockage....but thought I better throw that out there...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 02, 2009 | GE WSXH208A Front Load Washer
All of the water filling my kenmore washer is flooding out bottom
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 15, 2009 | Kenmore HE2 Plus Front Load Washer
Water overflows from drain pipe
2 ins is rather small and there may also be a partial blockage somewhere in the system you are not aware off.
a naughty cure is to restrict the drain hose of the machine so water comes out a bit slower
Sep 05, 2008 | GE WBSR3140DW Top Load Washer
Dishwasher
Check if any of these is the problem..
1)Drain hose is kinked or house drain is restricted.
Straighten the drain hose to improve water flow to the drain.
2)
Standpipe is too high.
Standpipe must not exceed 96 inches in height.
3)
Drain hose has been taped (or sealed) into the standpipe.
Tape holding the hose in the standpipe should not form a complete seal. The standpipe needs air for proper draining. Remove some of the tape to make an air path.
4)
Drain hose fits too tightly in the standpipe.
There must be an air gap between the drain hose and the standpipe for proper draining. The standpipe needs to be at least 1 1/4 inches in diameter.
Oct 22, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Same problem as Oct 8 2007 post - washer will not drain
The possible reasons and solutions for this..
2)
3)
4)
5)Also If too much of soap is used the washing machine drains slowly or will not drain at all..
Oct 22, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Water Backs Up in Drain Pipe and Overflows
the pump will pump out at a continuos rate that wont change, the problem will be with the standpipe. You dont have to have a total blockage in the pipe, sometimes the diameter of the standpipe reduces due to scale build up and it just cant cope with the rate of flow.There will be a restriction somewhere.
Jun 25, 2007 | Whirlpool LSB6200KQ Top Load Washer
GE WJSR4160DWW Top Load Washer Logo
98 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
