Question about Dell Dimension E521 AMD Athlon 64 X2 Dual-Core 3600+ , 1 GB DDR2 SDRAM , 250 GB EIDE SATA H... PC Desktop
I removed the old memory and installed 4 1GB cards and the computer doesn't work? Help.
    Scholar:
  • 74 Answers
Adding new memory can be tricky. First the new memory has to be compatible with the motherboard.
By that I mean, you need to know how much memory the motherboard can max out at.Can it take only 2 GB or 4GB etc. And it has to be a match to what memory speed your motherboard can handle. If your motherboard takes DDR than you must put DDR in, if it takes DDR2 than you must put DDR2 in. Look at the old memory, and try to match all the numbers you find on it. Than look up the memory specs for the motherboard to find out how much it can take.
Any computer will not operate corecctly if the memory is the wrong kind, or installed wrong.
Posted on Jul 02, 2009
Transferring photos from camera to computer
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 11, 2013 | Sea and Sea DX-8000G Digital Camera
Hp compaq 6200 not starting
A few things can go wrong when you are performing a computer upgrade of any kind, because during an upgrade, you remove and install parts, and it's easy for something to come loose, which may prevent the computer from starting.
Open the computer case, unscrew the video card and lift it out.
Make sure you move any release tabs before getting the video card out.
Put the video card back in place.
Check the nearby components, and make sure everything, especially the memory, is securely in place.
Close the cover and try to start the computer.
If it still doesn't start, replace the new card with the old card and check again.
If the computer starts with the old card, the new card is likely bad.
If it doesn't start with the old card, you may have shorted out the power supply and need to replace the power supply, but this is rare.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error.
Hope this helps
Nov 13, 2012 | HP Compaq 6200 Pro - Micro tower - 1 x...
Camera doesn't seem to be loaded in computer
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Nov 12, 2012 | Sanyo Cameras
All my photos will not upload to my computer
Aug 21, 2012 | Polaroid i634 Digital Camera
I connect my camera to the computer (mac) using a USB cable, and it doesn't come up
Yes, you need to charge the battery.
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 22, 2012 | Sony Cyber-Shot DSC-P10 Digital Camera
The camera doesn't download pics to the computer. It reads
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and isinexpensive. You can copy photos from other cameras and you can also downloadphotos off your memory card to someone else's computer without the need ofinstalling any programs.
May 05, 2012 | Canon PowerShot SD1200 IS / Digital IXUS...
While taking pictures my camera all of a sudden froze and said card error, tried putting memory card on computer but it won't read it have tried using recovery programs but it freezes them please help
If your memory card is 4GB or larger, AND if your computer is two or more years old, your computer's card reader might not be able to read the newer 4GB SDHC card. In that case, just purchase an inexpensive USB card reader from WMart, or Amazon (here's an example). Try a different card reader first to see if you can directly copy and paste the pictures from the card onto your hard drive. If the new card reader doesn't see the files, then try recovery software. Here's some freeware to try. If the software still doesn't see the card with the new card reader, you may next need to try the corrupted card procedures described at the bottom of this linked article.
Nov 26, 2011 | PNY 4GB Secure Digital High Capacity...
Problem in memory card is occurred in my Mobile. I tried to connect it with computer via card reader. When Click on Removable Disk, there is an error "Access Denied". Please help me in solving...
all you have to do is just connect with PC via Card reader, and then just format it.. if it formats successfully then i will work, and if its doesn't then the memory card is corrupted..
Jun 21, 2011 | SanDisk 2GB microSD Memory Card
I have a really old computer and I put my flash drive into the where it is supposed to go, but nothing came up. What am I supposed to do?
Some Flash Drives don't come with an "autorun" installed in it, if you have a Windows 7 Operative System, it might be installing the driver for it. If it's already installed, go to your computer menu and check if the drive shows up there (In the "removable drives/devices" area).If it doesn't show up, try plugin it in another USB port, your port might be the on not working.
May 26, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
No disk installer and memory card wont work
The 8025 doesn't have much internal memory. Without a memory card you can take a test photo but it will disappear when you turn off the camera. You REALLY do need to insert a memory card (SD or SDHC, up to 8GB in size) and format it in the camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
May 30, 2010 | Vivitar ViviCam 8025 Digital Camera
Dell Dimension E521 AMD Athlon 64 X2 Dual-Core 3600+ , 1 GB DDR2 SDRAM , 250 GB EIDE SATA H... PC Desktop Logo
75 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
