Stopped turning
Sounds like the belt broke. You will have to take the back off to find out. The other thing it could be is your brushes are burned out on the motor. If you hear it "turning" when it is on then it is the belt. If you hear nothing mechanized when it is on then it is your motor. You will also need to check the temp sensors. They could keep it from moving as well.
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
