Question about Konexx Mobile Konnector (KON60010)
No dial tone when connecting an HP 2840 AIO Color Laserjet with DSL on the same line?
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    Unable to send and receive fax from hp 3050 series
    check the phone line is properly connected and you are getting dial tone and dialing facility from the phone line which is connectd to fax line.go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
    Jan 29, 2010 | HP Color LaserJet 3500 Printer
    Hp 2840 prints color line on left hand side of paper
    What is the color of the line?
    If it's blue, replace the cyan cartridge. If it's red swap out the magenta. Do the same for the yellow and black.
    Dec 15, 2009 | HP LaserJet 2840 All-In-One Printer
    My Dell 962 All-in-one printer cannot detect a dial tone.
    Make sure that you the phone cable you are using is plugged into an active phone jack. You can take a phone from another room and test the jack.
    If you get a dial tone with another phone on that jack, then try replacing the cable that you use to connect the AIO printer to the phone jack.
    If that fails, the modem inside the AIO printer may be dead and it may be more cost efficient to just replace the whole AIO printer. Hopefully it's under warranty.
    Sep 02, 2009 | HP LaserJet 3030 All-In-One Printer
    Connecting problems
    Is it set to auto receive, is the tel line plug into socket marked line not tel. Is it used on a dedicated line, no extensions, if using ADSL you must have filter on line. If plugging standard phone in place of fax is dial tone heard and line is noise free, can you ring and speak fine on line using a phone. Is machine set to correct dial format for your country ie pulse or tone. When did it stop, have you had storms, phone work done, has it worked on this line before? I take it it copys ok is that correct.
    My bet is A noisy phone line or B set to manual answer. More info equels better help, but I am short of free time now..
    Feb 02, 2009 | HP LaserJet 2840 All-In-One Printer
    HP 2840 All in one won't print color
    printer is ok, check the connecting cable and drivers.
    Oct 28, 2008 | HP LaserJet 2840 All-In-One Printer
    HP 2840 scan to folder problem
    Kiss off your money and get a commercial grade AIO
    like Ricoh or Samsung. The 2840 has been a problem for us since the check cleared. 2840 Phone support is worthless. All the other HP products we have work perfectly every time.
    Jun 11, 2008 | HP LaserJet 2840 All-In-One Printer
    Konexx Mobile Konnector (KON60010) Logo
    93 people viewed this question
    Top Konexx Computers & Internet Experts
    David Payne
    David Payne
    Are you a Konexx Computer and Internet Expert? Answer questions, earn points and help others
