Why is Line spacing not working on Smith Corona 250 DLE?
SOURCE: Smith Corona 235 DLE doesn't advance
Does the platen move or does the paper not advance? Check the paper release lever to make sure the feed wheels are snapped in place. If the platen does not move something in the paper feed motor area.
SOURCE: smith corona typewriter settings
I am not sure but I think you the code key while pressing the format key then make the selection in the display.
SOURCE: SMITH CORONA KA 13 WORD SMITH
For a manual, try Google. Just put in "Smith Corona KA 13 WORD SMITH MANUAL'. If you can't find one there, then you are prabably out of luck. To change the margin simply go to the left margin, use the "backspace" or spacebar to position the print head where you want the margin set and then push the L MAR key. To change the right margin use the same procedure and hit the R MAR key.
SOURCE: Smith Corona 300 DLE--toggle from italics to normal type
SMITH CORONA TYPEWRITER 250 DLE. HOW DO I SPACE 1 AND HALF FOR TYPING?
SOURCE: need manual for use of smith corona model 250 DLE
YOU ARE NOT HELPING WITH ANSWER??????? WHY?????? I NEED TO KNOW HOW TO GET A MANUAL FOR USE OF SMI9TH CORONA MODEL 250 DLE. CAN YOU PLEASE ANSWER
