Question about GE Washing Machines
My washer pumps water into the standpipe too fast. It overflows all over the floor. Someone suggested restricting the flow rate by using a brass nipple in the drain pipe. How does this work and what size do it buy? Thanks
2 Suggested Answers
honeymokey
  • 3113 Answers
SOURCE: Washer drain problem
You have no problem with the washer, your problem is the pipes have a build up in the that is restricting the outflow of the water. This happened to me and I replaced the pipes.
Posted on Jul 02, 2009
Adora washer has given several years of trouble-free service. Lately, water overflows the drain standpipe and flows on to the floor. Machine washes, spins and rinses just fine - the overflowing is the only...
  1. If the drain water is overflowing the standpipe then you have a problem with the house drain not the washer.You need to clean out the house drain or call aplumber to do it for you.
Jun 17, 2011 | GE WSXH208A Front Load Washer
I have an electrolux front loading washing machine it is leaking water at the bottom and produces chunks of melted plastic during the cycle
Hello. If water is leaking from your washer, check the list below:
  • Is the drain clogged? If you have a clogged drain, it will need to be cleaned – contact a local plumber if necessary.
  • Is the drain hose restricted, or out of the standpipe? If the drain hose is out of the standpipe, you’ll need to secure it. You can do this by bending the end to form a hook, placing the hooked end into the standpipe, and tying the hose to the standpipe or a faucet with a cable tie (one was supplied with the washer), strong filament tape, or duct tape.
  • Are the fill hose connections loose at the faucet or washer? Check them and tighten the hose connections. If they’re loose, you might need to install or replace the rubber sealing washers.
  • Are you using a high-sudsing detergent or is your water soft? Using a high-sudsing detergent, or using too much detergent in soft water, can cause suds to overflow the washer. This may seem like a leak if the suds flow or drip onto the floor. Use a low-sudsing detergent and reduce the amount of detergent you use if your water is soft.
Apr 22, 2010 | HP DVD DRIVE DVD Drive
Ge FRONT LOADER WASHING MACHINE DRAINS TOO FAST AND IT OVERFLOWS OUT OF THE DRAIN PIPE ONTO THE FLOOR. IT HAS 1 5/8" DIAMETER DRAIN PIPE. SOLUTIONS???
Yes, the new front loaders do drain much faster...I find that you need to have a 2" drain for them to work properly without over flowing the standpipe.
Now, what can you do??
You can add on to the standpipe and get it up higher, this will do two things... the higher lift will slow down the pump a bit, but will make it work harder and possibly fail quicker...the higher stadpipe will give you a bit more reserve space for the water to collect and then flow down and catchup after the intial burst of flow from the pump. The higher pipe will also create a bit more pressure to push the water down the pipe.
The next and better fix would be to install a bigger standpipe and trap. Go right back the the main line and run a new 2" line and trap to the washer.
I assume that you checked the existing pipe and trap for blockage....but thought I better throw that out there...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 02, 2009 | GE WSXH208A Front Load Washer
Jul 02, 2009 | GE WJSR4160DWW Top Load Washer
All of the water filling my kenmore washer is flooding out bottom
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 15, 2009 | Kenmore HE2 Plus Front Load Washer
Tub in washer empties as fast as the water runs into tub
ck height of drain needs to be at least 30-36 inches from floor also be sure drain hose is only 6-8 inches into standpipe be sure there is a small air gap between drain hose and standpipe.. hose needs to fit loosely into standpipe or siphoning may occur
Aug 25, 2008 | Frigidaire GLET1031 Top Load Stacked...
Washer/limt trap clogging causing over flowing
Your machine has a trap, i dont understand the trap in the wall. The standpipe in the wall should be free of anything, which allows the free flow of waste water from the machine; to discharge water at a fast rate.
Plug off the wall, locate the trap -front bottom right side of the machine, unscrew, clean out, be prepared for some water. Refit. The pump-out tube into the wall should be at a particular height, about 3 fee from the ground. And dont push the tube too far into the standpipe.
Oct 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Water Backs Up in Drain Pipe and Overflows
the pump will pump out at a continuos rate that wont change, the problem will be with the standpipe. You dont have to have a total blockage in the pipe, sometimes the diameter of the standpipe reduces due to scale build up and it just cant cope with the rate of flow.There will be a restriction somewhere.
Jun 25, 2007 | Whirlpool LSB6200KQ Top Load Washer
Water overflowing from drain pipe
The problem with the new washing machines, is that they dump 20-22 gallons of water in 4-5 seconds. This amount is far more than the garden hose test will submit the drain to. Here are a number of solutions, I hope that one of these will help you.
#1 As mentioned above, you can restrict the flow of the drain pipe. I recommend a 3/4" x 6" brass nipple, or a 1/2" x 6" brass nipple, depending on your specific situation. The brass nipple will not corrode like a galvanized nipple.
#2 There is also a rubber cap that you attach to the drain pipe that fits around the drain hose tightly.
#3 Some situations might require that you have to raise your drain pipe. It is recommended that it be at least 36". This allows for gravity to assist the drain.
#4 Some situations will require that the drain pipe be increase in diameter. Older plumbing applications were installed using 1 1/2" piping. With the newer washing machine discharge volume, the 1 1/2" pipes will not support the discharge. Your drain line will need to be changed to 2". This option will be one of the more costly fixes, depending on the amount of line that needs to be changed.
#5 Some plumbing installations installed without a p-trap will need to be changed. The p-trap keeps sewer gas from coming back into the house. It also allows for a smooth transition into the drain line. Any restrictions in the drain line (i.e. ells, tees,) will cause the soap in the gray water to foam up which will cause the drain line to slowly back up.
I hope these solutinons help.
Jun 03, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
227 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
