Why does my camera eat batteries? I have to keep turning it off to reserve battery power.
SOURCE: Kodak Easyshare Z1285
Are you using the batteries listed as compatible according to the cameras battery door? Or are you using NON-compatible Alkaline or Ni-Cad batteries? Only Li-Ion and Ni-MH are compatible. Hope this helps...
SOURCE: Kodak Z700 not firing up
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
SOURCE: my camera eats batteries....no matter what kind I use
Sir,
Please follow these steps....
) You can lower the setting of your digital camera so that the quality of photo is reduced from the typical "standard quality" which comes set on the camera. What you will need to do is go into the options and reduce the quality to "economy" so that the battery expands less energy to take the picture, which will lead to longer batter life.
2) Make sure that you have calibrated your battery before you bring the camera along on your adventure. You can do this by charging your battery fully and then turning on the camera so that it dies. Once this happens you can charge it again and you will find that it will now last a lot longer than it formally did. I have found this to be very useful with all of my digital cameras.
3) In order to get the most out of your battery you should switch the battery in your camera from standard disposable batteries to rechargeable batteries. This is because of the fact that they last 2x as long as expand less to actually take the photo according to the Energizer rechargeable box.
4) You can go into the settings and turn off the flash if you see one when you are taking a picture. This will reduce the amount of energy going out of the camera which means that your battery will not die as fast as it normally would. You will need to select settings and then choose "no" next to the word flash.
5) You can also make your battery last longer by adjusting the settings so that you are not recording audio notes with your pictures. This will drain your battery fast so you should go into your options menu and select audio off. According to my Sanyo instruction booklet this will make your battery last up to an hour longer.
Thanks
Good Luck
SOURCE: My Kodak M1063 digital camera will not turn on no power at all
Kodak EASYSHARE M1063 Digital Camera My Kodak M1063 digital camera will... Answer my camera will not turn on no power at all.
SOURCE: Kodak m1033 lenses stuck 'open'.
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
