Question about HP Computers & Internet
Laptop screen goes black. - HP Computers & Internet
BLACK SCREEN
have you applied the heat sink paste between the fan and the processor?
if not do that
Aug 28, 2008 | Intel Motherboard
All i get is the acer intro screen and than screen goes black
Shine a torch at the screen when it goes black.
If you can see very faint windows, the back light faulty and new screen needed
Jan 20, 2014 | Acer Aspire Computers & Internet
Screen goes blank
I wonder which connector you are refering to. Sounds like a GPU issue to me.
Nov 27, 2013 | Acer Aspire 5500 5570-2609 Laptop
My HP Pavilion G6 laptop screen turns on and then goes blank (black)
When the screen turns on does it show anything or does it turn on and go to black?
If it goes to straight black it could be two things typically.
1. The LCD screen is having an issue. Connection cable / LCD screen itself.
2. The Graphics Card has gone out.
Jan 19, 2013 | HP Pavilion G60-235DX notebook
Black screen when switched on
Okay, does that laptop post to bios first? Example: You see the logo of the company before it goes to a black screen.
Also, do you see a blinking underscore in the top left hand corner?
Dec 09, 2012 | Computers & Internet
Hi I have a problem of black screen with my hp pavilion dv400. Wheen I start my computer I can windows logo on the screen but just 1 or 2 second and the screen go black. But when I connect my computer...
Your laptop is probably outputting the video signal to the wrong monitor. When the screen goes black, try pressing the function key to switch the video back to the laptop screen. Refer to your laptop's manual on what key to press. Usually it is the Fn key and F4 at the same time for HP laptops.
Jul 06, 2011 | HP Pavilion dv4000 Notebook
Black screen
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS.
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
Restart!
Mar 02, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Dell Inspiron 1525 Laptop..the screen goes almost black after 5 minutes.
The screen goes black while in normal mode right? So try to boot in safe mode (power on then keep tapping F8 then select safe mode). Check if still happens in safe mode.
If screen does not goes black in safe mode it means there might be a software or driver causes problem when running in normal mode. You can try the following (update your anti virus software then run a full system scan, uninstall the video driver then download and install the latest one, uninstall any previous windows update or you can system restore to the time when it was working fine).
If the screen goes black even in safe mode they try connecting the laptop to an external monitor if still goes black, if yes then absolutely no issues with the LCD panel. You can try (uninstall and reinstall the video driver if still persist then this might end up replacing video card or motherboard, but before doing that update the BIOS first).
If does not goes black in ext monitor then the LCD panel might causes the problem. Reseat the LCD cable or inverter if you can.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
Screen goes black after Windows Vista boot
Hello There is chance of serious problem with the screen of the Your laptop. This problem is often seen in case of HP laptop which are more then 6-7 months old. So if the laptop is under warranty they(customer care) will replaced the screen for free. If not the will charge few $ and provide you with original screen. Please check with the vendor from where you have bought your laptop. Regards Gizokieth
Oct 06, 2009 | HP Pavilion dv2310us Notebook
Computers & Internet Logo
255 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
