Question about Kirby G5 Bagged Upright Vacuum
G5 kirby's drive feature isn't working
Kirby works good, but is hard to push.......the direct drive feature isn't working. The lever seems to work, but nothing changes when you switch to the drive option.
  • Kirby Expert
  • 324 Answers
A gear set and drive belt are not that expensive and easy to install. You can find them here
GoodVac.com
www.goodvac.com
1-800-775-6586
Posted on Oct 16, 2014
  • 75 Answers
The gears or the drive is probably worn down or is broken.take it into kirby and they can fix it for you.
Posted on Jul 02, 2009
Kirby G5 only works when the power button is being pushed.
power switch damaged contact your local kirby agent for repair
Jun 02, 2012 | Kirby G5 Bagged Upright Vacuum
Neutral and drive grayandgreenonrear of kirby vacumn came out need instructions manual to fix model g5
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/G5/681827108464D2611112D4446409F328/G5%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 18, 2011 | Kirby Vacuums
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
G5 Kirby drive problem
Gary...
You need to adjust your transmission. Here's a link that may help...
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Jul 01, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5
nuetral/drive, the g series has a power drive motor for the back wheels
May 13, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
390 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
