Question about Eureka 2961AVZ Bagless Upright Vacuum
Burning smell and not picking up dirt
My vaccuum is not picking up anymore. I have washed and cleaned the filters and checked hoses for clogs. When vaccuuming, the unit smells like it's burning even when the height is on the middle setting. What am I missing?
  • 701 Answers
You probably need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Posted on Nov 19, 2009
Vaccuum picks up dirt going forward, but drops dirt when going backwards?
If it is an upright, check for a clog somewhere in the line leading to the canister. Also, the clog may be at the top of the canister.
Dec 24, 2014 | Vacuums
No dirt in cup and the red thing does not turn
Hello! It sounds like your vacuum has lost suction. This is caused by either a clog or a filter that needs to be cleaned or replaced. Please try these brief trouble-shooting steps.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Exhaust Foam Filter
Primary Filter
Hope this was helpful!
May 10, 2014 | Hoover Nano Cyclonic Compact Bagless...
It runs but not pick up dirt in cup
Hello! If the dirt is not entering into the dirt cup this could mean there is a clog in the vacuum or a filter that needs to be cleaned or replaced. Check that the brushes are still spinning. The vacuum has a brush-roll shut-off pedal on the right side of the cleaner if you are standing behind it. Below are simple instructions for checking your vacuum for clogs.
9. Inspect the belt for damages, if the belt is broken replace the belt with a Genuine Hoover belt part 562633001 Flat Belt Nano Upright
Primary Filter
Exhaust Foam Filter
Hope this helps!
Mar 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
Don't picK up the dirt and has a noise
Have you changed the filter? What kind of noise? Unusual high pitched noise? There could be debris stuck in the hose or the secondary filter/screen could be clogged. What were you vaccuuming when this happened?
Mar 13, 2011 | Bissell Vacuums
No suction
try to clean the filter of the vaccuum wash it with water.or dispose the dirt inside maybe your vaccum is full of dust. check the suction hose maybe it clog up or check the rotation of the motor maybe it has reverse rotation try to replace capacitor.
Feb 14, 2011 | Vacuums
The dirt is staying in the hose when I vacuum, not
that means there is no air flow thru your machine .. thats often caused by clogged (other) filters ..or sometimes a clogged hose .. you can check to make sure you can poke something thru the hose .. a stick or handle, hose or wire (making sure you dont poke thru the side of the hose) .. there are other filters and passageways in the unit that require cleaning or replacement .. if they get clogged then you will have your simptoms .. since there is lilttle air flow then the motor may overheat .. so dont run it long in that condition .. take all the "dirt cup" parts out and wash them all ...
Dec 22, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Bissell turbo revolution
you can wash that sponge filter by hand but you must let it dry compleatly before putting it back in the machine, I found a filter pack for the lift off vacume at walmart, make sure teh bottom filter is clean as well. the lift off vacume has 3 filters there is one filter in the tray under the dirt cup, one in the top cup, and the hepa filter in the back the 2 foam filters must be clean or you can have reduced suction, the lift off vacume I have I found thrown away because they never cleaned it outthe brush was dirty and full of strings the belt was worn, the hose under the vacume was full and stopped up the hose in the back was compleatly stopped up all filters were compleatly clogged, and the hepa filter was missing entirely. Not to insult you or anyone but i've found that a lot of people are jsut to lazy to clean their vacume out it fills up with dirt they throw it away and get a new one, i've gottten many like new vacumes for this reason, this bissell is working like brand new now. and I just replaced the belt and all filters in it saving me approx. 150.00 for a new one
Dec 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vaccuum forms in hose- will not pick up dirt
Check your wand for a clog. The DC17 line has common clog issues in its wand. It may be difficult to remove but if you have a long skinny pole(like one for curtains) you can use that to remove the clog.
Dec 05, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction, burning smell, expells dust
If by "suction" you mean it's not picking up dirt and debris on carpet, odds are your belt needs replacement, and the belt has burned, causing the burning smell. Ensure that your brushroll spins free, and replace the belt. (Belts should be replaced in any vacuum with a rubber belt every 3-6 months, regardless of use.)
If you mean that you are not having any airflow at the end of the hose, you most likely have a clog in the main hose and the burning smell is caused by your motor overheating. Ensure that there is nothing blocking the hoses.
If you have suction in the hose, and your brushroll is turning, there may be a clog in the head area behind the brushroll. Look in the hose that your wand plugs into, and ensure that it is also clear.
-R
Aug 05, 2008 | Eureka Vacuums
Eureka 2961AVZ Bagless Upright Vacuum Logo
630 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
