Question about Xerox Phaser 8500/8550 All-In-One Thermal Printer
No power getting through
My machine was not used for several months. When I plugged it in it turned on normal, but in a few minutes there was no more power to it. I have checked all connections - is there a fuse or something else that could casue this?
  • jerrylehrman Jul 02, 2009
    What do you mean by power adapter that needs to be changed - it is just a power chord like a computer has. Are you talking about something else? Or what do you mean by the power system in the machine?
  • jerrylehrman Jul 03, 2009
    I cannot get my Xerox Phaser 8500 to show any power when I plug it in. I have checked my cables and they work on another printer - so its not that. Do you have any ideas what else I can check?
    President:
  • 2,777 Answers
Hello there, yes you have blown an internal fuse as you initially suspected. You have confirmed this by checking the power cables so you know that it is isolated to the internal workings of that Xerox printer. There is a good chance that it could be under warranty still and will be replaced for free. Either way you will need an authorized Xerox technician to work on it. You can reach Xerox at:
1-800-ASK-XEROX or 1-800-275-9376
Their hours are:
Monday - Friday (except holidays)
8:00 AM - 7:00 PM ET, United States
8:30 AM - 6:00 PM ET, Canada
They will be able to help you schedule service, or get you the right part. Or they can point you in the direction of an authorized repair person in your area.
Sorry that there is no easy fix that we could provide for you! Please give Xerox a call, I think they should be there tomorrow (unless they consider it a holiday as some businesses are).
Thanks sir!
Tim G
timgrayson.net
Posted on Jul 03, 2009
  • 813 Answers
Try changing the power adapter. As far as I know there is no fuse in this model. Consult your service manual for any information on the fuse. Most likely the power system inside the printer has gone bad.
Posted on Jul 02, 2009
  • Dixit Sardana
    Dixit Sardana Jul 02, 2009
    yes, try changing the power cord. Power system means the unit that converts the AC voltage into the desired voltage as required by the different electronic components.
My keurig coffee machine won't work.
Try unplugging it and wait a few minutes,then plug it back in.
Jul 11, 2017 | Keurig Coffee Makers & Espresso Machines
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
Power Problem with Fisher RS 9015
Glad it helps, thanks also for choosing Fixya for assistance!
Aug 13, 2012 | Audio Players & Recorders
I purchased a Wii console about 5 months ago. I never played the thing because I dident have any games. I just recently got a game, went to turn it on and there was no lights and it wouldn't turn on. I...
First, Check your wii adaptor, In normal conditions the wii adapter provides the output 12volt. You can test the output using multimeter or a 12volt lamp.
then
plug it into the outlet, If the light is still off/flashing, disconnect the AC Adapter unplug from the wall outlet, wait 2 minutes and plug it back into the outlet. Turn the console power ON.
hopefully this help..
Mar 05, 2010 | Nintendo Wii Console
I have an 8710 workstation and it has worked fine for many months. Recently I've been having problems powering it on. I use a docking station and when I try to power it on in the morning -- the power LED...
Flashing orange light generally indicates battery low charge could be your battery at fault
the next time you try and power on and it doesnt work, take the battery out (unplug AC) and try to run just on AC power
hope helps, let me know if can help further
Nov 04, 2009 | HP Compaq 8510w Notebook
Hp deskjet 6540 power adapter turns on but printer doesn't
This printer have a problem on HP circuit board. Usually its grounded due to ink waste, or not using it like what you said it took about three months. Here is a tip if your printer HP is still under warranty then you can send or contact to HP Center or the one you buy from it. To be sure that your printer is working back normally.
Sep 13, 2009 | HP DeskJet 6540 InkJet Printer
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
Does the mouse & keyboard turn off or sleep?
check your windows settings. They are in your power settings. You can adjust your computer to whatever you want.
right click on destop and goto properties, then click on screen savers tab.. see the power settting button now?? You should be able to tell it what to do for everything to do with Power.
Apr 06, 2008 | Logitech Cordless Desktop EX110
43H70 43 in. Rear Projection Television
You will need to trouble shoot the power supply and shut down circuits. You will need the service manaul to do this properly , if you would like oe you can get one here at this link for 10.99 and they will email it to you and help troubleshoot your set for free. here is the link if you want the manual.
http://servicemanuals.vstore.ca/
Oct 26, 2007 | Toshiba 43H70 43" Rear Projection...
Xerox Phaser 8500/8550 All-In-One Thermal Printer Logo
42 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
