Question about HP Pavilion dv2700t 2.5GHz Intel Core 2 DUO Mobile T9300 4GB 320GB DVDRW DL LS WebCam 802.11a/b/g 14... (KQ654AA) PC Notebook
HP pavilion dv 2700 doesn't power up
Batterie jammed so I can't remove it.
LT does'nt power up if I try it beeps every 2 sec.
Light on power cord is ok and batt light is flashing which means charging.
This problem occured over night.
  • trauber548 Jul 02, 2009
    Unfortunatly this didn't help
    talked with a Staples rep he thinks the Motherboard is shoot and laptop has to be send in.
    Thanks for the advice
    Cheers
    Thomas
  • 34 Answers
Please check RAM.
Try removing the RAM. If you get the same type of beeps then replace RAM.
Posted on Jul 02, 2009
  • Saurabh Garg Jul 02, 2009
    Please check RAM.
Why hp dv 2-1030us blank screen one long beep two sghort beeps
Try these websites:
www.techsupportforum.com > ... > Hardware Support > Laptop Support
www.driversdownloader.com/hp-drivers/hp-pavilion-dv2-1030us...
If that does not help - call HP, most of the time they will help without a fee.
Jul 15, 2014 | HP Pavilion dv6-1030us Notebook
Batterie ne charge pas
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 02, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Pavilion dv 6500 dead ,the jack port lights up but nothing else
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
You particular mode probably has the Nvidia GPU Graphics Card in it and it's a well document known manufacturer's defect all over the internet. If you see lights blinking or hear beeps but nothing appears on the LCD Screen make sure you count the blinks and count the beeps. More than likely you have the Nvidia problem and you missed the recall and the extended warranty because HP got away without tell all their customers. The only way you would have known is if you just happened upon their website.
You'll need to get your Graphics Card Reflowed and that requires a complete disassembly of your laptop. Get a quote from your local repair shop then check out the guys at: http://www.generalsystemsconsulting.com
They will repair it and ship it back by Fedex or UPS and their price will beat most quotes including the shipping.
Mar 22, 2012 | Microsoft HP Pavilion DV6276US Notebook PC
During starting i get one beep every 2 sec.
Hello axel,
Before addressing the beep code, please unhook any devices you have plugged into the computer, such as printer, scanner, camera. Then try starting it.
According to hp that beep code is associated with a cd/dvd burner issue. Open up the computer, and pull the power cord out of it. While you have the case open, clean out any dust that is inside, overheating may be causing the issue. Place cover back on, and try starting it.
Next step is to reseat the hardware inside your computer, this involves removing components such as memory, video card(if present), and any additional hardware you may have.
Next remove extra hardware, If it is non-essential try starting your computer without it being installed.
including a link to common beep codes to use as a reference, They will change depending on the hardware you remove, such as memory, video, and the processor.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07107#N196
Aug 18, 2011 | HP Pavilion a810n (PP164AA) PC Desktop
My BOSS HP tx2000 will not turn on WHILE...
ok Do you hear any soun when your system try to boot?like a beep sound ?
try this remove battert remove the ac adaptor from the noatbookand press and hold the power button for 10 sec and connec the ac adapter not the battery and turn on the noatbook and at the HP logo hit the F 10 key for 2 times and you will be on bios screen hit the F9 ket and restore the setting to default and hit F10 agian to save and exit and allow it to boot it thats work try with battery connected
Regard!
Sep 16, 2009 | HP Pavilion TX2000Z Notebook
Need to down load web cam driver for hp dv 2700
whatever camera you are using go to any search engine and type the camera model and brand and after that say vista driver
Jul 09, 2009 | HP Pavilion dv2700t Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP power up issue
hi
you will have to remove the power cable and hold the power button for 7 sec w/o power cable and then try connection the power cable and turn on
2) reset the power connector on the mother board and try it
3) remove the memory and chk if you could listen to the beep if yes the mother board and power supply is fine so try removing the pci cards if any
Try those things
Regards
Samson Ved
Dec 10, 2008 | HP Media Center m7260n (EG642AA) PC...
HP ZD 8215 Laptop Start-up Problem.
2 beeps with no post means either you have a memory failure or the motherboard has failed
Jul 16, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion dv2700t 2.5GHz Intel Core 2 DUO Mobile T9300 4GB 320GB DVDRW DL LS WebCam 802.11a/b/g 14... (KQ654AA) PC Notebook Logo
252 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
