Question about Whirlpool AD25BBR 25 Pint Per Day Dehumidifier w/ AccuDry Sensing System & EZ-Empty Bucket Humidifier
Accudry dehumidifier freezing up
I have cleaned all the components inside and the air through is very good, but when I leave it on for a while, I have hardly any water in the bucket below, and the front grille is frozen on top. Thanks.
4 Suggested Answers
  • 10865 Answers
SOURCE: does not dehumidify
Hello. I am here to help. Let me begin by saying that a dehumidifier only needs to be operated if the humidity in your home is too high. If the humidity is low, the humidifier will have to work really hard to try and remove water from it.
Here is an overview of how the dehumidifier is supposed to work:
When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
Posted on May 20, 2009
  • 2468 Answers
SOURCE: Dehumidifier not collecting water
do the lines from the compressor to the evaporator freeze up or ice up anywhere,if so it could be low on refrigerant,also check the start capacitor in the compressor power circuit,if its bad the compressor won't run
Posted on Apr 04, 2010
heatman101
  • 43501 Answers
SOURCE: MY whirlpool accudry dehumidifier is not
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 14, 2010
Dehumidifer runs, but does not collect water. Just started this recently. We use it in the basement. Not too old. It's a Whirlpool Accudry.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Sep 07, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
DEHUMIDIFIER IS RUNNING BUT NOT COLLECTING WATER
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 28, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
I have a basement dehumifiier and I think there should be a way to clean the filter but don't know how to go about it?
you can unplug the unit,then remove top cover rear screw,then 6 screws on side of front grille,then all screws around the rest of the units wrap around cover,being careful to not stress any wires in doing so,then carefully blow out inside components out with low pressure compressed air or a vacuum cleaner
Mar 25, 2011 | Whirlpool AD50USR 50 Pint Per Day Ultra...
Whirlpool accudry dehumidifier doesnt work, the fan runs, but i think theres something wrong with the compressor, it clicks (on and off it seems) every bout 5 seconds. what could the problem be?
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Sep 14, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Apr 04, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Air blows cold rather than warm --- does not appear to dehumidy
it blows cold air and then it start to blow warm air what is the problem,
thank you
Michelle
Mar 13, 2010 | Whirlpool AD50USR 50 Pint Per Day Ultra...
Dehumidifier - hot compressor / coils not cold
If the compressor's running and it's getting hot and the coil isn't getting cold, then you are probably low on refrigerant or your txv or metering device isn't working.
Jul 30, 2009 | Whirlpool AD50USR 50 Pint Per Day Ultra...
Motor runs, but does not collect any water in yank
Make sure any air filters are clean. Check to be sure the evaporator and condenser coils are very clean. Also could the humidity level in your home just be very low right now and just no moisture to remove? If all of this fails it could be a compressor problem or a refrigerant level issue. If this is the case determine if it is worth the expense to repair.
Good luck
Mar 28, 2009 | Whirlpool AD25BBR 25 Pint Per Day...
Humidifiers Logo
113 people viewed this question
Top Whirlpool Humidifiers Experts
Paul Carew
Dennis
Are you a Whirlpool Humidifier Expert? Answer questions, earn points and help others
