Question about Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA
Haier HUF138PA upright freezer buzzing loudly
Our Haier HUF138PA upright freezer was left open for about 6 hours last night. Now (when it is plugged in) it makes an awful loud buzzing sound.
Unplugging it / replugging it does not help. Neither does flipping the on/off switch. The freezer itself IS working.
Help!
3 Suggested Answers
SOURCE: Haier HUF138PA-Freezer not freezing
just bought one that a repair man had already been through with similar issues. i wanted it as a fridge so this was no problem. took me about 5 minutes to figure out the reason it wasn't freezing though...the switch at the top that turns the light on when you open it also turns on the fan when you close the door. the door however sits just a tad too low to fully engage the switch. put a piece of tape over the switch and let it cool for 24 hours. chances are this will solve your problem!
Posted on Jan 20, 2009
Maytag317
  • 1136 Answers
SOURCE: MAKING A LOUD CLICKING SOUNDS
Hi, I am not familiar with this model but the noise sounds like a relay clicking at the compressor. Is the sound coming from the outside in the back?
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 24, 2009
Why is chester deep freezer making a loud buzzing sound
Have you made sure it is at least a couple of inches away from wall? It could be the metal rack on the back may be loose, or the feet aren't exactly level... Does it only buzz when cycling?
May 22, 2014 | Haier 13.6 cu. ft. / 385 liter Upright...
Freezer has stopped freezing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 26, 2011 | Haier 20.5 cu. ft. / 580 liter Upright...
Buzzer is going off and the door wont close and everything is melting
The air leaks through the door making the things melting inside. Please fix the immediately. Usually the problem is on door seal or hinges .
Jan 09, 2011 | Haier 20.5 cu. ft. / 580 liter Upright...
HAIRE FREEZER IS BUZZING
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Aug 11, 2010 | Haier 20.5 cu. ft. / 580 liter Upright...
Jan 10, 2009 | Haier 20.5 cu. ft. / 580 liter Upright...
Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA Logo
173 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
