If the mp3 player has a USB wire, plug that into the usb plug on your computer, then on your computer (if it is windows) go to START, and go to MY COMPUTER, and left click (double click?) this, to get a picture of your drives such as C:
One of the drives will be the internal storage of your mp3 player, and you can click to go into subfolders.
Just copy the mp3 file into one of the folders of y our mp3 player as if you were adding it to a hard drive or a usb drive.
SOURCE: cant transfer limewire music from my computer to my mp3
The Limewire music is located in your My Computer> C:>Documents & Settings Folder>Administrators Documents (your name)>Shared Folder. You can manually drag these files from this folder onto your device, located under My Computer>Device Name (there may or may not be a music folder, you should put it in there if there is). Once you drag & drop the files, you should safely disconnect your device, then you are done. Best of Luck.
SOURCE: sansa clip mp3 player
check drivers in xp or windows
do u have drivers cd ,
download drivers n install it.
ur's kishore chowdary +919441133420
Greetings!
Once you insert the mp3 player, the computer automatically detect the device, were you can see the folder inside of your mp3, create a folder from file, new, folder.
Now open the folder where the music was downloaded usually you can see that file at my document, save/complited folder, select all the file, copy
Open the new folder (which you created) in the mp3 then paste the songs that was downloaded.
To play the music in the mp3 player, just find the folder you created.
Thanks
