Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
SOURCE: need a lamp in my philips 50PL9126D/37 TV
Unplug unit and remove lower back panel should be 2 screws on each side and a few across the middle. Pull panel back and you should see a black box with metal folding handle. Remove the two left screws and pull out.
SOURCE: need to change lamp in philips hdtv model #
how do you get back panel off model 50PL9126D/37 philips tv ???
SOURCE: I have Philips 50PL9126D/37 The
The tv projection lamp in this tv been in the tv it like 2 years or more,tv in used daily like 4 or 5 hrs every day?The red LED light indicator is on,have a "LAMP"word written on the bazel frame?Yes,tv projection lamp life is over or eding.Tv reqire a new projection lamp.
SOURCE: philips tv 50pl9126d/37 help
Hello your problem is you have a bad color wheel that needs replacing.
