Whenever the water gets below the waterline the toilet will make a noise that produces air bubbles and brings the tank back to the level of the waterline ? What can be done to fix this ?
Why is the water leaking out of the tank? There's only reason for that, the water is slowly leaking by the plunger.check the plunger aT The bottom of the tank it's activated by the handle.shut the water supply off empty the tank,clean the bottom of the plunger refill tank .problem should be fixed if not replace plunger.. Happy plumbing.
