Question about Oregon Scientific Oregon Chainsaw chain for Homelite Chainsaw 18" Bar Length 64 Drive links 3/8 Standard 0.05 Gauge
What length chain is needed on homelite 360 proff. overall bar length 22" 19"from front of saw (extended)
    Sergeant:
  • 384 Answers
What is written on the Bar? If your Bar is a 22" then the chain will be packaged for that length Bar. Make sure you get the correct model chain for your saw.
Posted on Jul 02, 2009
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
https://www.youtube.com/watch?v=PnNTJ3xI_wo
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
HOW TO REPAIR CHAINSAW OILER - YouTube
? 6:38
https://www.youtube.com/watch?v=kmUkieIP-vw
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
What is the oil to gas ratio for homelite model 360?
I cannot find the full details for the model 360 chain saw but a typical Homelite chain saw uses the 50/1 gas/oil ratio.
1 gallon (US) 2,6 oz
1 litre 20 cc (20 ml)
If you want to download the user manual for your chain saw then please check the full model number . for example UTxxx and select this in the Homelite site.
Product Owner Manuals
Aug 21, 2014 | Homelite Garden
How do you measure the chain to make sure you get the right length chain on the saw. I have an homelite ez automatic.
The length should be printed on the bar. If it's not, I would take the chain with you to the store where you plan on buying the new chain.
Mar 10, 2011 | Garden
Bought a Homelite 14" electric chainsaw. After
I am not sure if you have figured out how to put the chain back on your saw or not, but it doesn't take long.
1. Remove the plastic yellow "T" shaped nut on the right side of the saw (towards the front of the motor housing)
2. Remove the black plastic housing that covers the rear section of the bar and chain
3. Place the chain back onto the bar making sure it is facing the correct direction.
4. Place the chain over the rear sprocket area
5. Turn the +/- yellow plastic knob (towards the back of the saw on the right side) in the - direction until the metal guide inside the plastic casing lines up with the hole in the chainsaw bar
6. Replace the black plastic housing and slightly tighten the yellow "T" shaped nut.
7. Now turn the +/- knob until the chain is tight. Once the chain is tight, turn the "T" nut until it is tight and you are ready to cut again.
Jan 30, 2011 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a J3816 chain saw. I need a new chain. What do I look for? I understand it is a Homelite in JD clothing. loadmike@yahoo.com
I don't know what suppliers you have in your area but where I live tractor supply, orechlins,and true value all have good selections of chains and knowledgeable sales staff. Most have a selection booklet that lists proper chain selections fo bar length, manufactures, chain type [ low kickback, fast cut, etc.]
You will need model number, manufactures name, chain length, type of chain you want. I would use the low kickback chain in almost all types of wood. About the only type of wood that I would use a more aggressive chain on is soft high moisture content woods like cottonwood or certain elms and pines. I hope this helps you. Thanks
Dec 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain oil tank full, feed channel behind guide plate clear, but no oil going to chain when running. This is a homelite 16.
There should be a oil adjusting screw on the bottom of your saw next to the bar beside the oil tank. Some models actually has the screw inside the tank. Drain the tank to make sure there isn't any debris clogging the hole where the oil feeds to the bar.
One way to check to see if the bar is oiling is:
1. Start the saw
2. Put a board, piece of cardboard or an uncolored old shirt in front of the bar
3. Press the trigger on the saw to allow the chain to circulate around the bar.
4. While keeping constant pressure on the trigger, look to see if there is a vertical line of oil on the piece of material you have placed on front of the bar. If the saw is oiling you will have a vertical line. If not adjust the oil set screw accordingly.
Nov 15, 2010 | Homelite ZR10926 16 Chain Saw
I HAVE A HOMELITE XL2 CHAINSAW WITH A 12 INCH BAR, CAN I INCREASE THE BAR TO A 14 OR 16 INCH BAR.
Usually, yes. Take the saw to a service dealer who can fit a longer bar and proper length chain. You will need to keep the chain properly sharpened and adjusted to prevent extra load on the engine. Hope this helps!
Aug 16, 2010 | Oregon Scientific Oregon Bar And Chain Set...
The chain on my chain saw is slack.
The adjusting screw is usually found on the right side of the saw close to the bar, near the bottom. You will need to loosen the two nuts on the side that hold the bar tight. Loosen them until the bar lifts up and down (about 1/2") with your finger.
There should be a combination spark plug wrench and screwdriver that came with your saw. If not, use a slot screwdriverto tighten the chain while you hold the bar up with two fingers.
When adjusted properly, there should be no hanging slack in the chain when it is warm. It should rest just against the bar so that you can grasp it with gloves on and pull it toward you.
When it is tightened thusly, tighten the two side nuts while holding the bar up with two fingers. If you don't tighten the two nuts enough, it will loosen and the chain will have slack again shortly.
Remember that the hotter the chain gets, the looser it will be. Make sure your chains is getting plenty of bar oil. Never use regular motor oil.
Jun 08, 2009 | Homelite ZR10926 16 Chain Saw
Length of bar on a Stihl 015 chain saw
measure from the very front edge of the bar back to the gripper teeth
May 16, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Oregon Scientific Oregon Chainsaw chain for Homelite Chainsaw 18" Bar Length 64 Drive links 3/8 Standard 0.05 Gauge Logo
107 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
