Question about Dell 1707FPv Monitor
1707FP MONITOR WON'T TURN ON. CHECKED ALL POWER SUPPLY, ALL OK. ON BUTTON WON'T DEPRESS
Hi, i have the same problem. i also dont know wat to do. i try everyting wat i can with other cable"s bud no result. if you been know wat is than please lat me know if i find problem than you been hear from me greating
Posted on Feb 04, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Generally this doesn't happen with Dell, I f you arn't using DLC or UPS there are chances of circuit break down in the display unit.
Posted on Jul 02, 2009
E19T5W monitor doesn't stay on once power button is depressed
Chances are the power supply in the monitor is going out.
Today, monitors are cheap and unless you have a 24' or better, it really doesn't pay. You may spent $100.00 and find one new for $135.00
Hope this helps
Mar 09, 2014 | eMachines E19T5W 19" Monitor
Power button is stuck on Monitor. It won't depress or turn on.
clean with alochol isopropyl by 30 minutes let it dry. and try again.However if the problem persist, TIME to replace the power button.God bless you
Apr 04, 2013 | Dell E207WFP 20" Widescreen Flat Panel LCD...
It is a Dell monitor, Model 1707FP. The screen went black and the power button is blinking. It does not make a difference whether I disconnect the video cable or connect it to another computer. What are...
http://s807.photobucket.com/albums/yy352/budm/Dell%201707FP%20Rev%20A01/
Check for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
Aug 12, 2010 | Dell UltraSharp 1707FP 17" LCD Monitor
NEC MultiSync LCD2060NX does not power up
Not user servicable and with the low prices of new monitors - not worth the cost of the part.
Oct 29, 2009 | NEC MultiSync LCD2060NX (Bezel) 20" LCD...
Power button damange ,
I used two thin putty knives this morning to open the monitor case. First, unscrew the four screws at the back. Then insert a putty knife into the small crack between the front bezel and the monitor shell. Carefully work you way around and wiggle the putty knives. Note that the front buttons are attached to the thin black edge at the front, and there's a thin cable at the bottom. Don't damage that. You can take off the back shell though.
Sep 09, 2009 | Dell UltraSharp 1707FP Monitor
Can't power on my DELL 1707FP monitor
Try a different wall outlet. If no go swap the monitor and tower power cables. I still no joy disconnect the power cord from the monitor, hold the power button for 10 seconds with the power cord disconnected. Try Plugin intu cable. If the screen is still dead check with dell tech support if the monitor has a warranty active on it. If the warranty is out get the monitor checked at a local computer shop.
Aug 08, 2009 | Apple Power Mac G5
No power after monitor is plugged and turned on
seen this problem many times, do as above stated. Return the moniter to where you bought it, if just purchased. Contact Acer if it is still under warranty.
Apr 13, 2009 | Acer AL1716 17" LCD Monitor
Power on/off button not working on Dell 17 in. Ultrasharp 1707FP
hi. probably de botton is damage or broken. if you have experience opening electronic devices like monitor you can replace that button you can purchase online. depending on the type of button, you can see a full tipe of button here: https://www.sparkfun.com/categories/145?page=all
Sep 16, 2017 | Dell UltraSharp 1707FP Monitor
Mag Innovision LT576s won't power up
Clearly your monitors are evil. Try turning them on at home and see how you fair out. :)
Cheers,
Mike
Oct 07, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Dell 1707FPv Monitor Logo
382 people viewed this question
Alun Cox
