Question about Rockford Fosgate Power 1001BD Car Audio Amplifier
Bridge jbl gto 600.1
Whats happend if i connect a ported box kicker L5 at 2ohms into a JBL GTO 600.1 in bridge, in the manual say cant be bridge the amp, how much power is in bridge at 1 ohm, can be dangerus if i ruing bridge?
  • 306 Answers
It will over heat the amp posibly blow it.....becareful
Posted on Nov 12, 2007
I am having a JBL GTO 601.1 amp and Pioneer SPL 2000 DVC Sub. Can the amp be bridged. How should I Connect the terminals, series or parallel.
I believe series.....hook a wire to the positive of one voice coil to the negative of the other.....with the remaining two wire that to the amp.....check on google to see if your amp is able to be bridged.....Most of the time on the bottom of the amp there will be a diagram or the the two outer speaker outs on the amp itself....let me knoe if this helps you...thanks
Mar 23, 2012 | JBL Car Audio & Video
Gto 7001 is it 2 ohm stable when bridged
It is 2 ohm stable. I have mine at 1.33 ohms and it still plays. It is 700 watts rms at 2 ohms per one channel.
Aug 03, 2011 | JBL GTO7001 Car Amp
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Nov 17, 2009 | JBL GTO 301.1II Subwoofer Mono Amp - 200W...
JBL GTO 301.1ii protect mode
Hello roets81,
Check the voltage at the amp. It's possible that the voltage is either too high (above 16V) or too low (below 8.5V). Also make sure that the amp case is not grounded. If these check out OK, the most likely cause is that the amp itself is defective and requires service.
Hope this helps.
May 27, 2009 | JBL GTO 301.1 Car Audio Amplifier
Jbl gto 75.4 right channel not working
It's rare that 2 channels will fail simultaneously, are you sending 4 signals to the amp or just 2?
If you are sending just 2, perhaps the problem lies before the amp in the cabling to it, or the output from the headunit. If you are sending 4 signals then there may be a fuse in the amp that drives 2 channels out of the 4. Of course this may be the case should you just be sending 2 signals.
Dec 25, 2008 | JBL GTO75.4 Car Audio Amplifier
JBL Sub Amp Wiring Please
it seems rather redundant to bridge a mono amp. Unless the instruction manual states otherwise, i would assume that one speaker output is identical to the other (ran in parallel, like an A or B speaker, not like Left or Right), and you would present the amp with a two ohm load by wiring one speaker to each output. Bridging it may or may not work, but, again, it just seems redundant.
Mar 01, 2008 | Car Audio & Video
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
Rockford Fosgate Power 1001BD Car Audio Amplifier Logo
526 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
