Question about Dishwashers
THE FAULT CODE IS F9 ON A FAGOR DISHWASHER
PLEASE ADVISE WHAT F9 INDICATES
Problem with distributor motor (or alternative motor). Motor locked, or sensor not detecting its rotation
Posted on Sep 19, 2009
  • jpt123 Dec 03, 2010
    is this easy to fix
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
Fagor dishwasher not completing cycle showing f6
The heater or thermostat is faulty and not allowing the dishwasher to complete cycle as water is not getting hot enough. Try to run a cold or short cycle and see if is completed.
see explanation of fault codes in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
Sep 21, 2014 | Fagor Dishwashers
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
Fagor 1vf65it
Fixya is unable to advise whether a pump can be easily obtained.
Feb 16, 2018 | Dishwashers
F9 in on the display
I am assuming the F9 is showing up only in one of the two drawers. It means the controller has a fault. Cannot do much short of replacing it.
Have you tried to turn the power off and back on?
It looks something like this. You could try checking with the controller on the other unit but don't want to end up with two faulty ones. So may have to order one and try.
Hope this helps. Please rate the solution.
Sep 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
No instruction manual
The instructions are available in
http://www.fagor.com.au/manuals/dishwashing/versionw/FI-48W,%20FI-64W.pdf
Hope this helps. Please post a comment to say if you found this useful or not.
Apr 20, 2010 | Fagor 24 in. FI-48W Dishwasher
FAGOR DISHWASHER LFU073IT WITH F9 COMING UP ON DISPLAY
Problem with the distributor motor. It is a small white plastic part which receives water from the heater, and alternatively distributes water to upper or lower difussors. If the motor locks, or the internal sensor doesn't sense the position well, it will show F9. Motor can be repaired in most cases, and at last, it can be swaped
Nov 28, 2008 | Fagor LFA-073 IT Dishwasher
Hotpoint fdw80 dishwasher
Faulty heating element. Had the same error and got Hotpoint to replace the element. Error was also confirmed by their engineer.
Apr 13, 2008 | Hotpoint 24 in. DWF32P Free-standing...
D3350 - Code F9
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
Dishwashers Logo
1,144 people viewed this question
Top Dishwashers Experts
