Question about Hisense LCD1504 15 in. Television
Cant get my hisense tv to av
I have a high sense tv , on the tv itself it has no buttons to change it to av, how do i go about it. it does have rca input jacks for dvd ect.
5 Suggested Answers
  • 223 Answers
SOURCE: INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Posted on Oct 01, 2008
  • 3 Answers
SOURCE: hisense
your Tv remort Or Tv Swich service Requied
Posted on Nov 12, 2008
  • 208 Answers
SOURCE: Unable to play DVD's
Hi, It is entirely possible that a couple of conditions could exist.
1) the DVD may support progressive output and the TV may not
2) the TV input could be defective or the DVD output could be defective.
Possible tests are -
You could test the TV input by substituting the dvd with another appliance known to be working (say a VCR. etc). the Y input (Green) on the TV only needs to be supplied with a composite output (yellow plug). If you see some sort of response from the picture then you can confirm the tv input is at least working.
Alternatively, try a different input/ output combination between your DVD/TV (Composite signal)
Posted on Mar 19, 2010
gopakumarg43
  • 74887 Answers
SOURCE: on an approximately 19" Hisense
Hello
You must ahve its original remote control to ulock your Hisense TV. If you haven't one, try to gather it from any of your friends or relatives who owns the same model TV; just to unlock it. After unlock, you can use universal remote control to operate it.
To unlock do the following.
[1] Press the "Menu" button on the remote control. The TV menu will appear.
[2] Tap "Channel ^" or "Channel v" to scroll the cursor between the menu options. Select "Function" and press "OK."
[3] Select "Parental Control" and press "OK." Enter the TV's password when prompted.
[4] Choose "Off." The parental controls will switch off and the TV will unlock.
OK.
Posted on Jul 09, 2011
When viewing a DVD from an external player connected to the tv how do I adjust the picture to maximise the screen size my hi sense tvn is a model 50K3300UW thank you
you may need to change the aspect ratio ... to change go to
1.
Press the [cog] button to open the Quick Setup
menu.
2.
Press the [>] button to
view the full menu settings
3.
scroll down to aspect ratio
4.
change to desired zoom format
Heres a link for your TV manual anyway...
https://ns323666.ip-37-187-156.eu/manuals/Hisense%20LED%20Television/Hisense%2050K3300UW%20LED%20Television.pdf
Good Luck!
May 06, 2017 | Televison & Video
How do i connect a smart tv that has hdmi to rca cables
Utilize the MiFine AV. This is a great product I have used many times located here or anywhere you can find it. I have only used this brand as many other reviews have stated they have problems with the cheap ones from China.
Mifine AV to HDMI HD Video Audio Converter 720p 1080p Mini 3RCA Composite CVBS to HDMI Switcher Portable AV2HDMI Adapter for TV/PC/PS2/PS3/PSX/Blue-Ray DVD
I purchased one for about $30 USD and you can use if for any device that has RCA cables such as a video recorder, VHS player, Wii, etc
Best Wishes,
Joe
Aug 25, 2016 | Hisense 55 2160p LED Ultra HDTV Class 4K...
Rca L40FHD41is stuck on menu,cant change input or volume . how to reset the tv???
Unplug the TV for a few minutes it should reset itself.
Make sure the menu button is not stuck, if it is try cleaning the button.
www.aaatvservice.com
Jan 28, 2012 | RCA Televison & Video
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
How do u change av on tv withoute remote
Directly on the TV there should be a button marked AV/Source/Input. That would be the button to press till you reach the desired input.
Thanks
Dustin
Jan 04, 2011 | Hisense Televison & Video
How to connect sound system to Hisense LCD tv
I phoned the help line at Hisense, they stepped through the set-up - its all good now
Dec 30, 2009 | Hisense TL3000 30 in. HD-Ready LCD...
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
Hisense
Sep 18, 2008 | Hisense LHD3204US 32 in. LCD HDTV
Hisense LCD1504 15 in. Television Logo
136 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
