Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
  • slick254 Jan 23, 2010
    Great answers and after I had already opened the drain line temporarily 2 times I finally called a pro. Turns out that not only the drain line was clogged but the automatic ice maker was broken so instead of running water into the tray it was dripping it down onto the coils and pan and the big freeze occurred. Thanks for the answers.
My GE fridge drain tube froze up twice within two weeks causing the fan to stop. Pouring hot water down the tube cleared the drain but only temporarily. The last time the technician took the back of the fridge and saw that the drain hose was curled up in a "U" shape. It was freezing at the U junction. He simply cut the tube so water drained straight down and no problem now for two years. I think a planned defect to encourage consumers to purchase a new fridge every few years. Otherwise, why not publish this fix. My sister had the same problem with her GE fridge and after two repairs, just bought a new fridge. Probably could have been repaired with the same fix I had. Shame GE!
Posted on Jan 23, 2010
  • GE Master
  • 1,606 Answers
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Posted on Sep 16, 2009
My does my g&e profile leaks water?
I am assuming that this is a refrigerator. If it is leaking and you do not have an ice maker installed, then the problem is probably the drain hose from the freezer is blocked. All refrigerator freezers go through a defrost cycle to keep frost from forming in the freezer section. Every time you open the freezer door to access the freezer, moisture from the air is allowed in. The freezer from time to time shuts down and allows the ice crystels which were formed by the moisture to melt. This water then is drained through a drain hose down the back of the refrigerator to a pan under the coil at the bottom of the refrigerator. The heat from the coil evaporates the water into the kitchen air before it overflows. Check the hose and drain to be sure there are no kinks in the line and that it is not blocked. That should solve your problem.
Aug 09, 2014 | GE Refrigerators
My monogram refrigerator leaks water from the upper left side/top of the freezer.It is a model ZIS- 42
you have a blocked/frozen evap drain tube leading to the pan, located directly above the freezer section. in all honesty donot believ this to be a repair homeowner should attemp i would contact an authorized ge servicer.As a maytg/ whirpool servicer myself , i know in our built in refigs we have new heated drain tube/evaporator pans that we installe possible that GE has as well
Mar 14, 2008 | Refrigerators
Whirlpool freezer won't freeze
you need to send the model number so i can see what fridge you have,is it a side by side freezer on top or bottom.check the back inside wall of the freezer to see if any ice or like snow is on the back inside wall of the freezer,if so you have a defrost problem,if it's a top freezer is there any water leaking into the fridge section,check under the crisper draws,if water is there you could have a blocked drain in the freezer,the water that's from the defrost mode leaks into the air ducts and freezes,or you could have a freon leak in the sealed system,remove the inside back wall of the freezer and check the frost pattern on the evap coil,if there's frost just on the top of the coil and nowhere else on the coil you have a freon leak,one more thing you could have a bad evap fan motor,open the freezer door,you should hear the fan blowing around,open the freezer door and push and hold the door or light switch in for a minute and then let it out,if the fan doesn't run it could be bad.the last thing is the compressor isn't running and you're hearing the condenser fan running and not the compressor,the start device on the compressor could be bad,feel the compressor,is it hot and feel it to make sure it's running.so bad start device,freon leak,defrost problem or bad evap fan motor or condenser motor.if you get back to me and let me know what you find and send the model number i can help you better.
Nov 02, 2011 | Refrigerators
When the freezer defrosts,water drips into the refrigerator. I assume a tube is disconnected. How do I get to the area between the freezer section and refrigerator section to look at it.
sounds like the defrost drain line is blocked,what is the model number?is it a top mount freezer on top?if so remove the back inside wall of the freezer,unplug the fridge or if you have the tech sheet usually found on the bottom kick plate it will tell you how to put the machine into defrost,this will help melt out the ice,when you remove the back wall melt out the ice with a hair dryer,next you have to clean out whatever is blocked in the drain,below the evap coil you'll see a hole,that's the drain,i use a steamer to blow through the drain,this works the best,you can try a turkey baster or anything that will blow through the line,when you think the line is clear,pour hot water down the drain,if it drains through you're done,if not keep at it until water will drain through.
Mar 20, 2011 | GE Refrigerators
Ge profile fridge side by side makes only 8 ice cubes per day
Good day,
Assuming the temperature in the freezer is normal. 10 degrees or less. then it should be one of the 3 items here.
1. Partially plugged filter.
2. Water valve in the back bottom of the machine failing to open properly.
3. Partially blocked supply line from the house or it's connection fittings which ar more common than the line itself.
As well, if the water fill valve has a small leak on the off cycle, the fill tube running from the outside back of the machine that supplies water to the ice maker cavity may have ice starting to cause a blockage.
Nov 06, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE J SERIES MODEL TBX25PAXCRWW WITH KNOCKING NOISE WHEN MOTOR SHUTS OFF.
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Feb 28, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
Fridge Motor
which one?evap fan motor or the condenser fan motor?i've seen the evap fan blades in the freezer wear out in the center where it slides onto the motor shaft so when the motor comes on the blade doesn't spin with it,need a new blade,or if the freezer is on top the drain blocks and the air vents freeze up,is there water leaking anywhere or ice on the freezer floor?need to send a little more info,also model number would help
Jan 23, 2010 | GE Refrigerators
Kenmore Refrigerator, water forming on glass shelves then freezing, little ice around the thermostate gauge area, banging sound once in a while.
next time send model number and say where the freezer is located top, bottom side by side,if it's a top mount,could be blocked drain,take back wall off in freezer,melt out ice under the evap coil with hair dryer, then i use a steamer to clean out drain line,slime forms in the drain and usually has to be blown out if you have some kind of plastic water line or something you can stick in and blow out that line,or try pooring hot water down drain,after you get it to drain call the local parts store and get a heater probe,this will keep the line from clogging in the future,hope this helps
Nov 07, 2009 | Kenmore Refrigerators
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
474 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
