Question about Brother MFC-3240C All-In-One InkJet Printer
Spooler service i cannot install my printer because an error message says that the spooler service is not working. what does that mean?
  • 42 Answers
Depending on the version of windows, you need to open the services control panel: (assuming XP or greater)
Start, Control Panel, Admisistrative tools then choose services. Look for print spooler and see if it's disabled. If not, then is it set for maunal startup. If it's manual, change it to Automatic startup and then start it.
If it's missing, greyed out or starts with an error... then you might have a problem in windows with malware, virus or adware and that is beyond the scope of the questions at hand.
Posted on Nov 09, 2007
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
Jan 11, 2013 | Office Equipment & Supplies
What does it mean when i get the error message print spooler services not running
you need to turn it on, Go, . START>>RUN>>services.msc enter. When the services screen comes up, scroll down until you find the "Print Spooler" Enable it, Start it, and set to Automatic, reboot, ya good to go.
Mar 15, 2010 | Brother HL 2140 Laser Printer
"fatal print spooler error" error message
Completely uninstall the printer driver and install again. If this does not work, there is a corruption in the windows registry or in the print spooler cache files.
For a temporary workaround, disable print spooling. But, if you do, you will need to remember to never close an application you print from until printing is actually finished.
Jun 28, 2009 | Konica Minolta magicolor 5430 DL Laser...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using
Jan 27, 2009 | Office Equipment & Supplies
HP print spooler problem and error 1068. Want my printer back!!!
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
Tried to install new printer model#PIXMA MX310" received an error message "processing cannot be completed because the Print Spooler service has been stopped"
Ok what that means is you need to re-enable the printer spooler service on the computer, below are the directions to do so
  1. Hit the "Start" button
  2. Hit "run"
  3. In the run box type "services.msc"
  4. Hit "Enter"
  5. A box will come up with all of the services , scroll down to "Print Spooler"
  6. RIght click on "Print Spooler" and hit "Restart"
  7. Right click on it again and hit "Properties"
  8. In the middle is a drop-down box that says "Startup Type" , select "Automatic"
That should fix you right up!
Oct 05, 2008 | Office Equipment & Supplies
right click on my computer -> select manage -> one should be services and something (or something like that) open that and go to services -> find the printer spool service and right click on it -> click on properties -> in the printer spool service properites click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic".... This is what you did right ?
Log in to Administrator account and try it there. If that doesn't work then install a fresh copy of Windows Xp. It should work now. Thank you.
Sep 07, 2008 | Office Equipment & Supplies
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
ahah..first things first...what Windows Operating system do you have...??
Feb 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
52 people viewed this question
James Cagle
James Cagle
Jim Keysor
