Question about Magellan RoadMate 1430 GPS Receiver
Magellan roadmate 1430 calibration is wrong
The calibration is off i reset it and i still cant get to user options
    President:
  • 1,111 Answers
Try a hard reset again using a paper clip, insert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update (if you havent already) off the magellan site..you must register the unit with magellan before you can download the update.
Posted on Jul 30, 2009
Change my magellan roadmate from canada to usa
This model does not have map coverage of Canada. This model was designed for us only in the US. The models in that series with Canada maps were the RoadMate 1212, 1412, and 1430.
Oct 12, 2014 | Magellan Roadmate 1200 Car GPS Receiver
My gps touch screen does not seem to operate.I have tried resetting many many times.
try the calibration screen in the options menu and follow the directions...make sure you hold the screen over the X until it moves to the next position.
if that fails, you might need a digitizer...let me know and ill help you
further
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
bill
Standing Member of G.O.T.
Oct 03, 2010 | Magellan RoadMate 1412 Car GPS Receiver
The power won't come back on
there is a fuse in the tip of the plug that goes into the socket. unscrew the end of the plug to gain access to the fuse.
Mar 31, 2010 | Magellan RoadMate 1430 GPS Receiver
Can you download an update for a magellan roadmate 1430?
Yes you can: Enter your info here http://www.magellangps.com/support/
English Manual: http://docs.google.com/viewer?url=http%3A%2F%2Fwww.magellangps.com%2Fassets%2Fmanuals%2Froadmate_1430_manual_en.pdf
Magellan® RoadMate® 1430 Software Update Version 3.12: http://www.magellangps.com/support/chooser.asp?prodid=2056&supportid=806
2009 Spring Map Update: http://www.magellangps.com/products/map.asp?tab=0&PRODID=2194
As for connecting it to the computer, you'll need the usb cable that came with it. Then you'll want to do this:
Follow these steps to connect your Magellan RoadMate to your PC.
  1. Turn ON your Magellan RoadMate.
  2. Touch "Map" to display the map screen.
  3. Connect your GPS to your PC using the USB cable.
Oct 19, 2009 | GPS
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
It is shutting down while we are using it. it is plugged into the lighter outlet and has power, does not show a low battery
try a hard reset first using a paper clip, innsert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update off the magellan site..you must register the unit with magellan before you can download the update.
Jul 29, 2009 | Magellan RoadMate 1430 GPS Receiver
Magellan roadmate 1430 no sat signal
replace the or recharge the battery to capacity and see if that helps usually low battery, incorrecty baud rate or port out cause no satellite connection, unless you are under a thick concrete or tin roof. take it outside and show it some sky and see if that help
Jul 23, 2009 | GPS
Roadmate 760 Touchscreen
There should be a calibration option in settings.
Please rate my help++++Thanks for using FIXYA
Jul 07, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan roadmate 1412 is set to wrong region, how do i change regions?
At the main Menu, touch right arrow, select "User Options"-->Region and select the desire region.
Feb 27, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Magellan RoadMate 1430 GPS Receiver Logo
722 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
