Question about Sony DCR-HC18E Mini DV Digital Camcorder
Firewire / iLink transfer failing -HELP please!
This is driving me up the wall... I have the same cam (Sony DCR-HC18E) and am trying to transfer my miniDV tapes to the hard disk on my Sony Vaio Laptop (Vista Home Premium) via the iLink / Firewire cable. I've tried through Click to Disc, WinDV, Roxio and Windows video import software but none of them are recognising my cam... they can't find anything to import. Also tryed on my standalone Hitachi DVD Recorde which has an iLink port... no joy there either. I'm getting very frustrated... what am I doing wrong????!!!!!
  • 10,594 Answers
Go to camera menu and turn on USB Streaming and try to download movie. Still no joy, iLink port seems broken / faulty.
Posted on Jul 02, 2009
I dnt hav usb cable for my handy cam DCR-HC52E ...
Product Summary
    4-pin to 4-pin IEEE 1394 iLink FireWire Cable dv out to laptop Connect and transfer home movie from your digital camcorder to Notebook computer.
    You will need a Firewire port on your computer, also known as a DV port or IEEE 1394, to use this cable. This is NOT a USB cable.
    This DV cable will connect your laptop (notebook)
    NOTE: for some models, becuase of no DV jack on the body, this cable connects to docking station/cradle instead of connecting directly to your camcorder.
Mar 20, 2011 | Sony DCR-HC52E Mini DV Camcorder
Cant instal drivers
usb streaming function is not readily supported by windows vista. this would depend on the software that came supplied with the camcorder. unfortunately, the software being incompatible and the funtion (usb streaming) not supported by driver included in the supplied cd-rom, usb connection will not work (although you can use it for still picture transfer). for tape transfer you would need to go another route which is ieee1394 (ilink or firewire) connection. it should be a plug-and-play connection. your computer should support and have a working ieee1394 (ilink or firewire) card installed. a compatible ilink cable for both devices and a video capturing software like windows moviemaker and having all the needed hardware and software then your good to go. hope this helps.thanks:)
May 29, 2010 | Sony Handycam DCR-PC330E Mini DV Digital...
IMovie 09 / Mac OS X will not recognise Sony DCR-HC35 via firewire or USB? Do I need to download the correct driver?
mac doesn't support usb streaming so that leaves us with firewire. it should be a plug-and-play connection. no need to install any kind of driver for the camcorder (but try to check if there are any available driver updates for the firewire card).if possible try to check if your computer firewire port is working by using other devices.your imovie software should detect the camcorder once connected.if not, disconnect cam, open imovie, and connect again.if still doesnt,RESET camcorder.if still the same try restarting computer with cam connected and powered on.check if you have a dv in indicator on your screen.check if firewire cable connection is secured.try diff ilink cable if available.if still no go, try a diff computer. if everything fails might also be a service issue.hope this helps.tnx:)
Apr 16, 2010 | Sony DCR-HC35E Mini DV Digital Camcorder
I have a sony pc 100 dv cam. I am trying to find the right cable to connect it to my mac. I need what ever sony uses one one end and usb on the other.
your camcorder doesnt support usb connection.although it came with a pc serial cable,its the cable used for memory stick picture transfer, along with it comes a serial port adaptor for the memory stick and ac adaptor for serial adaptor. of course even if you lost this accessories you can still transfer pics from the ms using a memory card reader which works basically the same way. for videos on the tape you would just need a firewire or an ilink (ieee1394) cable. almost all mac computers support this connection.it's the dv in/out jack on the camcorder with an i symbol.upper most jack on the camcorder jack's location.check your mac to find out what cable you need.the unit uses a 4pin ilink port so you need a 4pin ilink cable at one end and the other end should match of course, the firewire port on your mac computer.should be a plug and play connection.you can use imovie software for video capturing.hope this helps.thanks :)
Mar 11, 2010 | Sony Handycam DCR-PC100 Mini DV Digital...
SONY HANDY CAM DCR-HC18E PAL Need download for usb driver windows vista
http://support.sony-europe.com/dime/tutorials/videotransfer/vtransfer.aspx?site=odw_en_GB&m=DCR-HC18E&sec=DV
Only load the driver and install in XP compatability mode then use another video capture programme Sony does not support Vista for you cam.
FX vid capture will work
http://www.jhepple.com/video_capture_software.htm
If you get stuck you can reach me on marshall.c@sky.com
May 27, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
A sony dcr-trv 103 camcorder and I want to connect to computer
Yes, the brandnames Firewire (Apple) and iLink (Sony) are both IEEE 1394 interfaces.
Your cam should require a 4-pin to a 6-pin, both IEEE 1394. Hope this helps.
Apr 20, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Failure to connect my dcr-trv265e sony cam in windows vista
You need iLink (firewire/ IEEE1394/ DV) cable to transfer movei files from DCR-TRV265E to PC and PC should have DV port to plug-in.
USB cable will not give you such facility.
You can see iLINK cable here.
Jan 03, 2009 | E.Digital Sony DCR-TRV265E camcorder Pal
Unable to use firewire Sony handycam DCR-HC 54E (mini DV)
Anyone try this on Windows XP? Apparently firewire doesn't work with Vista.
Dec 10, 2008 | Video Cameras
DCR-TRV285E PAL
Could u plas help me to find the installer for DCR TRV 285E PAL. I want to transfer the video to the pc
Nov 09, 2007 | Sony DCR-TRV285E Digital-8 Digital...
Sony DCR-HC18E Mini DV Digital Camcorder Logo
423 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
