Question about Saws
Lowering blade makes sqeaking sound - Saws
    President:
  • 1,996 Answers
Try oiling the gears and worm drive. (Blow out the sawdust first.) I use straight 30w motor oil which works just fine, in an old fashioned pump can.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 23, 2009
The right side blade is cutting way lower than the other 2 blades. Z500, Z series toro zero turn
Sounds like you hit something and damaged the blade. Look under the deck to make sure both blades are level and tight on the shaft.
Aug 09, 2014 | Garden
Sqeaking sound when i start in the morning
have you tightend it enough so there is not a lot of play in it if so its probably one of the pully bearings or the alternator bearings going i would check these first hope this helps ivan ps check power steering fluid levels as well as when the resivior is empty they make a squicking noise
Oct 05, 2012 | 2001 Lincoln Continental
Bernina 140 which has a sqeak in its Handwheel How do I fix it
it's sounds like the machine needs to be serviced when they start sqeaking or making odd noises
Mar 06, 2012 | Bernina Activa 140
Fan makilng lot of noise
Possible that the bearing are bad or that the blades are rubbing on the sides due to a faulty bearing assmebly.
Sut down the engine and manually turn the fan and if there is sqeaking sound then the bearings are faulty or the fan assembly needs a change depending on the nature of the damage.
Have some oil sprayed into and see if there is any change .
Sep 05, 2011 | 1989 Toyota Camry
I'm getting clunking noise out of the front drivers side and a sqeaking noise.
noise when you turn? cv axle
noise going stright AND sqeak- strut
May 27, 2011 | 2003 Chevrolet Cavalier
Blade is tipping on the wheel and ruining the blades just wondering how to adjust the wheel. or is it the top wheel or the bottom ,one must be out of line
It sounds like the upper wheel is tilted out and what happens is the blade will drift outward. What you need to do is power off the unit, open up the upper and lower wheel doors, find the adjustment knob on the back of the upper wheel, and adjust this while spinning the wheel by hand.
The blade needs to be on the machine when you do this and do not try to make this adjustment with the power on. Make small adjustments till the blade tracks in the center of the upper and lower wheel.
NOTE: Prior to re-elignment, make sure the tension on the blade is set to the correct tension. This will differ depending on the blade thickness. You want the blade to be tight, but don't over tighten the blade because this could cause wear or even cause the blade to snap when using the bandsaw.
I hope this helps.
Nov 18, 2010 | Saws
I have a Gelatao Magnum Plus that makes a horrible sqeaking noise
Maybe blade assembly it's loose, or bearing are dry, if you can take apart, use grease on the shaft and bearings. or replace motor.
Dec 23, 2009 | Kitchen Appliances - Others
Front end sqeaks on my 2004 vtx honda 1300
Sounds like the brake pads and possibly the brake caliper.
Jun 11, 2009 | 2004 Honda VTX 1300
Noisy Fan
we had the same problems. Made awful sounds and was very loud. We finally had to replace the fan at the cost of $230. sorry! better to replace it now than to lose all of your food
Apr 11, 2009 | Samsung RS2630SH Side by Side Refrigerator
I hear a sound like the fan belt sqeaking, I know there is only one belt and that belt is still on . first it made a sound like a tire was leaking air then i heard the sqeaking under the hood
belts can still sqeak even though they are still on, check the condition of the belt, is it craked?, glazed? spray some silicon spray on it while its running and see if it goes away. the belt driven accesories can also make noise, alternator, steering pump, water pump, idler, tensioner, a/c compressor. use a long screwdriver like a stethescope and see if one belt driven acessory makes more noise than the others, just be careful of moving parts.
Mar 16, 2009 | 2001 Ford F150 Styleside SuperCrew
Saws Logo
35 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
