Question about Denon AVR-3806 Receiver
I have lost the red in my video to the monitor. I
I have lost the red in my video to the monitor. It occurs with all the components . I have changed cables and the same results . It satrted when I was checking the cable connections in the back of the unit. I've even substituted the cable with a HDMI cable
    President:
  • Denon Master
  • 1,114 Answers
If it happens on all "input" sources and you have changed the receiver "output" from component to HDMI and you have the same issue, your receiver has a video board problem and needs service. Depending on your systems setup and the available inputs of the TV, if your receiver is out of warranty, you can use it for audio and run video straight to the TV. Hope this helps
Posted on Jul 02, 2009
Light is on and green but no video coming out to television what might be the problem.
Typically, this problem occurs if the audio/video (A/V) cable is not connected correctly, or if the A/V cable is faulty.
Solution 1: Set the television or monitor to the correct input
Make sure that the TV or monitor is set to the correct input for the console. Check the TV or monitor's manual to see how to configure the video inputs, or try to use the console on a different TV or monitor.
Solution 2: Connect the A/V cable securely
Sometimes, you can insert the A/V cable far enough to prevent any red lights from flashing on the Xbox 360 console but not far enough for the console to transmit images or sounds to the screen.
Solution 3: Switch the Xbox 360 Component HD AV Cable to the correct setting
Make sure that the TV/HDTV switch on the cable is set correctly.
  • For standard-definition TVs with only the yellow connector plugged in, set the switch to TV.
  • For high-definition TV or monitors with the red, blue, and green connectors plugged in, set the switch to HDTV.
For more solutions, check this web page.
Oct 09, 2010 | Microsoft Xbox 360 Console
My tv won't turn on...the red light indicates that it's plugged in, but everytime i press the power button, i get nothing! can someone help?!
If warranty no longer valid, the first printed circuit board I would investigate is the one with all the aluminum heat sinks on it!!! It's called the "switch mode power-supply" !!! Power supply detects a "fault condition" and goes into "shutdown mode" to save itself from catastrophic component failure!! e.g. smoke, sparks, fire. Same typical failure modes occur in CCFL back-lit lcd computer monitors. You will need to visit YOUTUBE for video clips of "lcd monitor disassembly" and "lcd monitor repair" and after that move up to CCFL lcd tv repair videos to know just what to "LOOK" for on the smps board. Good luck with your unit. 12fixlouie
Sep 20, 2010 | Broksonic CCVG-3276 32 in. LCD TV
Red pixels
They are are called dead pixels. A TFT monitor is built of millions of tiny lamps(LEDs) in matrixes of the tree colors, Red, Green and Blue, these have like any other electronics component a limited life span. When dead, sometimes they stop reacting to the color changing control signal and keep emitting only one color often red(IMO because the other two components are more stressed by the higher frequency). Unfortunately this phenomenon is irrepairable. :(
BR
Feb 28, 2010 | Televison & Video
My Dell M991 TCO-99 monitor has lost the red colour i.e. there is NO red at all, an of course all the other colours are affected - shifted towards blue - is it the end of the CRT or can it be fixed by...
I'm assuming the red is gone completely; that is, it's not present at all and not just missing in video from the computer. If that's the case, you probably have a bent pin in the VGA connector, a bad signal cable, or possible video card failure.
The missing red might be due to bad solder connections. These often develop around parts that get hot, like the color output transistors. They also can occur on the circuit board that plugs onto the end of the CRT. If you're comfortable with electronic soldering you could examine the boards and repair any connections that look dodgy (grainy or visibly cracked around the component lead).
It's also possible there's been some component failure, and you won't be able to find that without some test equipment and experience with troubleshooting. It could be the CRT itself that's had it, especially if it's been around a while. Sudden loss of one of the colors is a very common failure mode.
Bottom line is check the soldering if you really want to keep this monitor, but beyond that don't bother repairing it. Not many servicers will work on computer monitors. And the cost of repair is likely to be uneconomical. New LCD monitors are quite inexpensive, and repairing your CRT one may approach replacement cost.
Feb 03, 2010 | Dell M991 19" CRT Monitor
Component Wii comes in as B&W. TV and PC both work well
yellow has to go to yellow. Green = Y which only allows for luminance and chrominance. Hook the wii into a yellow connection and you will have no issues. red white and yellow are composite, not component.
Dec 25, 2009 | Samsung T220HD LCD Monitor
The computer has lost all the red color and others
Hook up another known good monitor to the video card and if it still has problems with red then you know the video card is bad and needs to be replaced.
If the known good monitor still works after being hooked up to the video card then you know the original monitor is bad.
Let me know if I can be of further help.
Ben
May 14, 2009 | Gateway GT5220 PC Desktop
CRT Monitor Not displaying blue components
Your moniter's video circuit is faulty .
Jul 08, 2008 | Gateway FPD2275W LCD Monitor
Samsung monitor blacks out --
The problem should be dry joints in powersupply section and horizontal output section.Resolder all components mounted on heatsinks HOT Vertical O/P Ic etc.
Samir
Jan 07, 2008 | Gateway FPD2275W LCD Monitor
Component conecters
alright...those are Component Connectors...your DVD, and VHS will not work with that Monitor at all.
The Best and Cheapest Option...is to Buy a "Modern" DVD Player...which almost every single one Has Component Connectors.
On your Current DVD, VHS...ECT. The Red and White is Audio respectively, and the Yellow is the Video.
On a Component However the Red, Blue, and green...are all Video. You will need to use your "Current" Red and White Audio Jacks from your DVD and VHS Players on your New Monitor, and New DVD Player.
As Far as VHS is concerned...if you Buy a DVD/VHS Combo...you should have a S-Video Jack on Both the Monitor, and the DVD/VHS Player...Buy a S-Video Plug.
With that you will be able to watch both DVD's, and VHS Tapes without issue
Nov 26, 2007 | MegaVision MV220 Monitor
Lg 563n monitor problem
Plz check your monitor's vga cable for ok .I think there is problem in 1,2,3 no pins wires continuity.If it is ok then check components thats are connecting these pin to video amp. ic on crt neck.If they are ok then change video amp. ic with new one.Hope this solution works otherwise i am always ready for help
Sep 10, 2007 | LG Studioworks 563N 15" CRT Monitor
Denon AVR-3806 Receiver Logo
51 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
