Question about Sanyo Televison & Video
Since digital switchover yesturday loss of digital channels
Since digital switchover yesturday my tv after retune cannot pick up bbc1,bbc2,bbc3,cbbc or bbcnews24. Rescanned DVD recorder with no problems so not ariel problem. How can I get TV to scan a larger range ?
  • Anonymous Mar 26, 2014
    TV dosn't pick up channel 9 and no other TV in house can get channel 9 when new LG TV is connected to the ariel system. If TV dose not have an earth it dose not effect the other TV
    Brigadier General:
  • 3,006 Answers
It may well be your aerial despite the success with your DVD recorder.
Digital signals are very much weaker than analogue ones, and when multiple devices share a single aerial you can get this kind of problem. You also lose about 60% of the signal at each point in your aerial cable where there are signal splitters.
There are a number of possible solutions:-
First, look at every bit of coaxial cable you have between the aerial and each appliance. Check especially at the aerial end for corrosion or poor shielding/installation and especially for evidence of rain water penetration. If the aerial is on the roof then it will cost almost as much to get the aerial inspected as it will to have it replaced, so skip to the next option. But otherwise, check along every bit of the cable for any cuts or splits in the insulation and properly remake every junction or joint if there are any doubts about them. If the cable is in poor condition then consider option three instead.
The second is to try to see if you get a better digital signal from another transmitter, this will involve trying different aerial positions so is impractical if your aerial is roof mounted but is worth trying if it's in the loft instead. It doesn't always follow that your best digital signal will be from the transmitter which you used for analogue transmissions.
Thirdly, if you're still using the same aerial as you have done for years then it's worth upgrading to one optimised for digital reception. When doing this it's foolish not to replace the cabling as well as you need it to be as good as possible. With analogue, many installers got away with using cheaper cable intended only for very short cable runs from the wall socket to the tv.
The fourth option is the budget option but can work as well as the third option: fit an additional analogue style aerials and run a separate cable down to each appliance. If these are fitted in the loft and you have the space, then there's no aesthetic or planning concerns. Normally the extra cables can run partway down through the house alongside existing cables, but for best signal quality keep them separate and ensure that the cable runs as as short as possible.
One further thing which you may want to try before all else: connect your digital box directly to the aerial cable which currently feeds your dvd recorder. Leave all other tv devices disconnected from the aerial. If the box retunes correctly then it's definitely a supply of signal issue as outlined above and if not then you should add the exact make and model of your digibox as a comment to this answer as there are a large number of earlier digibox models which cannot retune correctly due to evolving standards.
Posted on Jul 02, 2009
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
Lost BBC1 BBC2 digital after switchover
You might have more than one transmitter. Some TV's etc only store a certain number of channels and have a max amount!. When weaker transmitters are present sometimes the memory of the TV will only store the stronger signals first from these weaker sites, with the two BBC channels being too weak to be detected.
The solution is to do a manual search on the transmitters you know are very strong. For example if channel 43 has strong signal you would search on that. The auto search will start at 21 and work it's way to 69. But if your area transmitter with the strongest signals is high up the scale the weaker transmitters will be selected first!
Apr 09, 2012 | Electronics - Others
Panasonic lcd tv model no. tx-26lmd70. since switchover day 6/4/11 i have not been able to receive bbc1, bbc2, bbc3 channels auto tuned 3 times a day to no avail. panasonic helpline is jammed with other...
This This is a difficult one . You may have to go online to get an Upgrade for the TV..You will need a flash drive and of course there must be a USB socket on your tv... Other than that im stumped. Sorry.
hope this helps
Apr 08, 2011 | Panasonic Televison & Video
Since retuning Novemder 2009 cannot receive BBC1, BBC2 or BBC3
sounds like power surge. try unplugging unit from wall. wait 2 minutes. this reset the microprocessor in the tv. plug back in and enjoy!
Nov 09, 2009 | Toshiba 50H81 50" Rear Projection...
Problems withthe digital switchover and retuning my freeview box!
There are a few problems turning up as a result of the update. Do a factory settings on the box if it has the option to do so. Be aware of the actual transmitter you are on and the channels/frequencies it uses so when tuning you know whether its finding channels at the bottom, middle or top of the band. Sometimes you may need to unplug the aerial upto or after a particular channel to stop the box tuning unwanted transmitters. If you are picking more than 1 transmitter up you will often get extra channels in wrong locations
Nov 06, 2009 | Philips Televison & Video
After retuning digital tv my TX-28DTX1 BBC1 BBC2 BBC3 are missing. I have tried several times. Another tv in the house using the same aerial has found those channells.
It is a software problem with the television. I found the answer on the internet. I have contacted Panasonic for an upgrade of the software.
Oct 02, 2009 | Panasonic Televison & Video
Digital switchover
I also have the Sony IDTV KD-28DX4OU Digital TV.After the digital switchover I lost BBC1 and BBC2 despite retuning three times.
I contacted Digital switchover people (useless) and they passed the buck to Sony.I contacted Sony and they said they cannot fix the problem and that I should get a digital set top box. So the £650 I spent on integrated Digital TV has been wasted.If like me your cheesed off with this then I suggest you complain here
Sony United Kingdom Limited
Customer Information Centre (CSG)
Jays Close
Basingstoke
RG22 4SB
I have
Sep 30, 2009 | Sony FD Trinitron KV-28FQ75 28" TV
No BBC 1 or 2 after digital switchover.
I have the same box and re-tuned mine with the same results as you.However i discovered that the NEW BBC channels were on the channel guide list starting at channel 800
May 07, 2009 | Televison & Video
Since digital switchover i cannot recieve bbc1/bbc2
In upstate N.Y. I know that when you go to buy the converter boxes that if you don't know to ask the store for a converter box that picks up the canadian channels as well as the american channels, the store won't tell you. You end up with a converter, half a converter I feel. Make sure you ask for the right one if you watch canadian tv.
Nov 10, 2008 | Durabrand Televison & Video
Televison & Video Logo
340 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
