Question about Garden
The engine starts but the rotor that holds the strings wouldn't rotate it is a brand new trimmer
  • 155 Answers
Sounds like the shaft was not assembled correctly this would be covered under warranty
Posted on Jul 25, 2009
Why does my new Craftsman 4 cycle Trimmer's head turn counter clockwise
Curved shaft trimmers turn clockwise.. straight shaft trimmers turn Counter Clockwise. Also the Bump head is reverse threaded because of the engine rotation.
When using this trimmer , Angle the right side of the string line down so the grass gets thrown in front of you not at your legs.
May 30, 2015 | Craftsman Garden
The starter pull cord on my gas trimmer will not pull.
Hi Mark
Perhaps a bit late now.... Just spotted this so I imagine it's all fixed by now.
But for others with this sort of problem.
Assuming the pull cord is not broken, stuck or tangled. Switch off or short plug to ground, for safety then remove the spark plug to allow the engine compression to escape. You should be able to turn the engine over really easy with the pull rope, otherwise the engine might be seized or the rotary pull mechanism jammed.
Also... can the shaft to the string line be rotated as in the crankshaft of the engine.
Good Luck
Aug 30, 2014 | Echo New String Trimmer SRM-225 2 Stroke...
How to restring drum on Echo 210 gas trimmer
Pull the head off by turning the inner hub counter clockwise while holding the outer head still. Once the inner head pops out, turn it over and look for the string rotation arrow. If you can't find the string winding directional arrow, start the trimmer and determine shaft rotation direction (generally counter clockwise) and wind the string in the same direction as the head rotates when installed.
Pull about 5 arm lengths of string out of a string spool and cut it off. Place the inner trimmer head on an object that will hold it while you pull the string to even lengths through the winding hole (the support brackets of a pickup truck tail gate work well for holding the inner head while doing this).
Begin wrapping the string double wraps in the proper direction, laying them evenly and closely to the previous wrap, working it back and forth as the string begins to build up. Avoid crossing the string over itself more than necessary, the string can weld itself together if the strands cross to awkwardly. Once the string is wound, hold the head with one hand and slide the string through the outer head holes, avoid letting the string come unwrapped.
Carefully place the inner head down into the outer header. Avoid letting the string get caught between the inner and outer head. Once the heads are together lock the inner head onto the outer head by turning it and locking the round knobs into the outer head slots.
You can trim the string or let the trimmer guard do it. If the string doesn't feed it is either wound the wrong way, tangled between the inner/outer head or welded to itself.
Aug 19, 2014 | Echo Garden
I have an echo gt 225 string trimmer with the curve shaft and it isn't starting. I moved switch from stop to switch as manual says and purge fuel bulb and switch on cold start but it wouldn't not...
Without knowing more about your trimmer, the most common problem with two cycle engines is the carburator. If carb sits to long with fuel in them, as would be the case when storing for the winter, the fuel can break down gumming up the inner workings of the carb. There are rebuild kits out there, but if this is your problem, I suggest purchasing an new carb. The price of new carb is only a small amount more than trying to rebuilding the old carb.
Jan 12, 2018 | Echo Rapid Loader, Trimmer Head
MY BATTERY IS LESS THAN 1 YR OLD. I AM TOLD THERE IS A RECALL ITS A LITHIUM 18 VOLT
I wouldn't hold your breath. They have been selling trimmers with cheap batteries forever, that is how they get their costs down. You can either keep buying new batteries or just switch to a different trimmer. I recommend plug in or gas.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
I bought a new grass trimmer, gardeners choice, it would not start, noticed the end were you put the nylon keeps turning around,some how that shouldn't, .
Your trimmer may not have a centrifugal clutch, and if that is the case, the string head will turn when you pull on the starter rope and it will always rotate with the engine running. The trimmers with the clutch don't engage the drive shaft until RPM's are up to a certain speed and when that speed is achieved, the clutch engages the clutch drum, the flex drive turns and the string head begins spinning.
May 07, 2011 | Garden
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
