Question about Buffalo Technology Gigabit LinkStation HD-HG250LAN (HDHG250LAN) 250 GB Network Storage Link
Noise then death
Mine made noise for awhile then it finally died. I think that HD went bad. Sounds horrible if I try and start it up.
  • tanderson Nov 09, 2007
    The sound intermittent and is almost a thwack like the arm is trying to move but can't. It does have a fan but if it were bearings I'd assume it would be a constant.
    I'll take the hard drive out and do some research one the warranty for that.
    Thanks for the great advice.
  • 42 Answers
I would agree with you, unless that model has a fan and the fan bearings are out. Bearings will make a huge noise when they fail. But, you mentioned it's also dead.... so it might actualy be. Even if the unit is out of warranty, sometimes the hard drive inside has a 3 - 5 year manufactures warranty. Depending on how the unit works internally, you might be able to replace that hard drive and continue on.
Posted on Nov 09, 2007
Grinding when turning key on to start ignition
Dodges have a gear reduction in the starter, usually. It could be wearing out. Have it checked out at a rebuild shop.
Nov 30, 2013 | Cars & Trucks
I have had starter issuses for my 1992 ford taurus sho3.0 for awhile now and finally got to changing it out today it sat for two days and awhile in that time i went out to bang on the starter to get it to...
If you have a carby check that the auto choke is working correctly. If is set too tightly closed it will flood the engine every time and pumpin the pedal will not help the situation. Mostly the correct adjustment should be almost closed but will open under air flow.
Feb 03, 2013 | 1992 Ford Taurus
The screen color started flashing funny. I turned the TV off. When I turned it back on, it makes a horrible groaning almost grinding noise, on and off, then finally stops trying to do what ever it's trying...
This tv have a colors wheel,it dying,now it dead.Colors flashes black&white and grinding noises,the colors wheel was spinning off of it motor axis and rubbing it sides wall.The colors wheel,now require changing to make the tv work again.The colors wheel it pretty hard to replaced,because it require take out many machanicals parts even can get to the colors wheel to replaced it.Best it to hire a tv tech. to do the job.If u never done or change anythings,that require take out alots and many machanicals parts before.
Oct 20, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Ktm wont start
sounds like you may have over adjusted the decompressor, back it off to where it was, this would make it backfire.
To kick them, push the kickstart through its stroke until you get to feel the compression as it approaches the compression stroke, then use the decomp to kick it just past top dead, let the decomp go and then kick it, no throttle
Apr 19, 2010 | 2004 KTM 625 SMC
Jumped the battery after car sat for awhile then
If you dont use the car it still use the battery so sounds like you need do slow trikle charge on the battrie. If that dosent work you might killed the battrie off. i dont this many time if not use it die fast.
Jul 29, 2009 | 1999 Buick Century
Our 2000 Merc Villager had the engine light on and was making some sputtering noises. It died in the middle of my husband driving it. We went to have it towed the next morning and it started okay so he...
Could be cam sensor, crank sensor, PCM going bad. On these newer vehicles with all the electronics it is hard to pinpoint what it is till the check engine light does come on for it. I would suspect one of the 3 going bad though.
Jul 11, 2009 | 2000 Mercury Villager
1997 Honda Accord ABS makes a "grinding" noise when turned on
Have you had the master cylinders replaced? Mine made this exact noise and they replaced the master cylinder.
May 11, 2017 | 1997 Honda Accord
Buffalo Technology Gigabit LinkStation HD-HG250LAN (HDHG250LAN) 250 GB Network Storage Link Logo
199 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
