I'm going to look at a used seadoo and I am really interested in it. I'm looking for some pointers and key things to look for when I go to look at the machine. When I go I want to be able to look for the right things so I don't buy a bad machine.
Where can i find the vin numer on a seadoo
If you want to buy a jetski. I highly recommend yamaha. Especially if you plan to ride in salt water. Well anyway check for cracks and abuse.have the owner start it with a hose connected to make sure the pump works. Look inside the engine make sure no water is coming in while its running. Ask him/her if they cleaned it after evry use. If it was winerized. Ask if they use wd-40 and sprayed the motor down after every use. Make sure you do that also no matter what you buy. Clean it a spray down the motor with wd-40. I have a 95 yamaha the motor starts up with no issue every year for 14 years now. If all is good tell him/her you want to test drive it ski will always run better without a load (out of water) than with a load. if it runs good with a load then go for it. Change the plugs every year keep it clan with wd and always run fresh water through it when down to clean it out. enjoy. its a great sport.check into pwc today .com and h20.com
