Question about Casio Office Equipment & Supplies
Display related problems during calculations - Casio Office Equipment & Supplies
How ican repair tha calculator weach on dameeg the papar
Posted on Jul 02, 2009
Number not displayed
No. A bad battery (or power connection) would cause the entire display to fade, not just one digit.
Given the relative prices of hardware and labor, it probably would be cheaper (and quicker) to just buy a new calculator rather than trying to get it fixed.
Oct 09, 2013 | Texas Instruments BA-II Plus Calculator
My HP 12c is showing 0,00 on the display...if I add 2 plus 2 it shows 4,00. Not sure how to reset? It also has a blinking * which I understand is a low battery indicator...are these two things relat
No, they're not related.
To switch the radix mark, turn the calculator off, press and hold the decimal point key, press the ON key, then release both keys.
Feb 18, 2013 | HP 12c Calculator
How do i remove the c on the bottom of the screen
The C status display indicates that the calculator is set for compound interest during the odd period. To use simple interest for the odd period, press STO EEX.
Jul 07, 2010 | HP 12c Calculator
I am getting the wrong results when performing some basic FV math problems. Doy you have any math problems that would help test my calculator?
It might be more efficient to make the calculator perform a self-test. Here is the procedure.
Verifying Proper Operation (Self-Tests)
If it appears that the calculator will not turn on or otherwise is not operating properly, use one of the following procedures.
1. With the calculator off, hold down the [ON] key and press [X] (the multiply key)..
2. Release the [ON] key, then release the [X] key. This initiates a complete test of the calculator’s electronic circuitry. If everything is working correctly, within about 25 seconds (during which the word RUNNING the display should show –8,8,8,8,8,8,8,8,8,8, and all of the status indicators (except the * battery power indicator) should turn on. If the display shows Error 9, goes blank, or otherwise does not show the proper result, the calculator requires service.
Tests of the calculator’s electronics are also performed if the [+] key or the [divide] key is held down when [ON] is released. These tests are included in the calculator to be used in verifying that it is operating properly during manufacturing and service.
If you had suspected that the calculator was not working properly but the proper display was obtained in step 2, it is likely that you made an error in operating the calculator. We suggest you reread the section in this handbook applicable to your calculation — including, if appropriate, appendix A.
If it needs repairs, contact FixThatcal.org
Here are some examples from the manual (there is overlapping in the first two screen captures)
Mar 07, 2010 | HP 12c Calculator
The calculator is not showing any display after replacing the battery of HP 12C
Try verifying Proper Operation (Self-Tests)
Feb 21, 2010 | HP 12c Calculator
Display reads DEG on top with L under when I turn on. will not clear
When you turrn calculator ON the angle unit is reset to Degree and the DEG indicator is displayed. I do not know what the L is for, but you can get rid of the DEG indicator during calculator operation only if you change angle unit to RADians or GRAdes. However it will be replaced by the indicator for the new angle unit. After the power down, the unit will be back to the default DEG. What can you do about that?
Hope it helps.
Oct 06, 2009 | Texas Instruments TI-30XA Calculator
I have an HP 12C calculator and I cannot find the user manual and I cannot remember how to change the no. of decimal places?
Check this HP FAQ:
Setting a Fixed Decimal Place You can download the manual and user guides for your calculator from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=81575&lang=en&
For more information, Faqs & how-Tosgo the HP support homepage for your calculator:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=81575&
Introduction This document describes how to set the desired number of decimal places on the HP 12c calculator in standard format. It also covers how to enter a number in scientific notation. Instructions for standard format
  1. Press and release c01774993.jpg .
  2. Press the number key for the desired number of decimal places to be displayed to the right of the decimal point (0 through 9). The calculator displays a maximum of 10 digits.
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected. Example (standard format) If the number in the display is 14.87456320, the display will be changed as follows: Keystroke Display c01774994.jpg 14.8746 c01774995.jpg 14.9 c01774996.jpg 15 c01774997.jpg 14.87456320 Instructions for scientific notation Use scientific notation for very large or very small numbers. Type in the mantissa. After pressing, c01774998.jpg the next numbers keyed in are exponents of 10. Press c01774569.jpg . If during an operation a result has more than 10 digits, the calculator automatically displays the number in scientific notation
Aug 24, 2009 | HP 12c Calculator
Addition Problem with HP 17BII
do a self test
1. Turn the calculator on.
2. If you have the optional infrared printer, turn it on. Certain diagnostic
information is printed during the test.
3. If possible, return to the MAIN menu (press @A).
4. To start the self-test, hold down C while you press the fifth menu
key from the left. Once the self-test has begun, do not press any keys
until you are ready to halt the test.
5. During the test, the calculator beeps periodically and displays various
patterns and characters. Watch for one of two messages that are
displayed before the test automatically repeats:
􀂄 If the calculator passes the self-test, the calculator displays
􀂄 If the calculator displays     followed by a five-digit number,
6. To halt the self-test, hold down C while you press the third menu
key from the left. The calculator displays             . If you
press any other key instead, the test halts and the calculator displays
a     message. This results from an incorrect key being pressed,
and does not mean that the calculator requires service.
7. If the calculator failed the self-test, repeat steps 4 through 6 to verify
the results. If you do not have a printer, write down the messages that
are displayed in step 5.
Jan 01, 2009 | HP 17bII Calculator
Power-up TI-85
Come on, It's the contrast. Turn it up with [2nd] [↑].
Dec 30, 2008 | Texas Instruments TI-85 Calculator
51 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
