Question about Acer Aspire One A150-1006 Notebook
Problems with Acer Aspire ONE A150 netbook Machine turns off after 30 seconds. On going. (And yes I can see the screen so its not that). Keep trying to boot up, get through windows XP load, then populate the desktop... doesn't quite finish before the time runs out and swithes off.
How do I reset my acer aspire one A150 to factory setting?
Instructions
Click "Start" and select "All Programs."
Click "Acer Empowering Technology," then "Acer
eRecovery Management."
Click "Acer eRecovery Management" in the Acer bar
that appears on your desktop. The "Acer eRecovery Management" window will open.
Click the "Restore" button.
Click "Restore System to Factory Default." Click
"Yes" to confirm. The system will restart and reset itself to factory settings.
Aug 24, 2013 | Apevia Aspire One A150-1777 Netbook
My Acer Aspire one won't go past windows xp loading page but i can get on through safe mode, how do i get passed windows without it restarting?
go into safe mode then restart
when it turn back on press f8 buttonrepeatedly until the option screen appears select last known configuration option you should get in
May 30, 2011 | Apevia Aspire One A150-1777 Netbook
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
I have an Acer Aspire One netbook (model AOA-110) and when i try to boot it up it goes to the boot up screen and brings up a black screen and asks if i want to choose safe mode, safe mode with networking,...
Frequently ACER ASPIRE ONE A110 and A150 hang and give a black screen of death. Most probably this is due to the BIOS problems and if you want to boot them again, a BIOS updating is required.
First, download the required BIOS from the Acer site:http://gd.panam.acer.com/home/ and unzip it by another computer. (Your netbook is already dead!)
Among the extracted files and folders, there is a folder namely Dos_Flash. Open it and there are four file items there like "3310, 3310.fd, FLASHIT, and readme.
Now rename 3310.fd as ZG5IA32.fd and FLASHIT as FLASHIT.EXE and keep the rest as they are.
Copy all these four files to a fully formated and blank USB stick. In this USB stick there should be no other files or folders than what you copied now ( 3310, ZG5IA32.fd, FLASHIT.EXE, readme )
Keeping this USB stick in hand go to the dead netbook. Switch off the device if it is already on. Insert the USB stick. Having the AC power and the battery connected to the device press and hold FN+Esc and simulatneously press the power button to turn on the netbook.
Release the FN and Esc buttons after a few seconds and now the power button will be blinking. In this stage press once the power button alone.
Now the device will start updating the BIOS, we can see the process as the LED of the USB stick flashes. In a few minutes-say less than 10 minutes-the system will restart and come to life again.
Don't disturb it during this process and wait until it comes to full level of operational condition to remove the USB stick.
Best of luck,
M K Pukayoor,
Malappuram Kerala India.
Dec 26, 2010 | Acer Aspire One AOA110-1588 Notebook
How do you format an acer netbook?
When the acer screen comes up press alt+F10, if it doesn't work then you need to restart your computer again, load the BIOS and enable it.
May 19, 2010 | Acer Aspire One A150-1006 Notebook
My Acer Aspire One A150 screen is damaged and in inverted colours
"I got somebody to replace the screen for me and it was working until now" this more likely affects your warranty as the warranty seal is tampered..
What did the guy do to get it right did you replace something or just got it serviced..??
I don't user acer but my friend had problems with his lap DVD drive n got replacement. It took 2 weeks though
Sep 05, 2009 | Acer Aspire One PC Notebook
Screen flickers on Acer Aspire A150 Netbook
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 08, 2009 | Acer Aspire One A150-1006 Notebook
Need a virus scanner compatible with ACER A150 Netbook
TRY DOWNLOADING AVAST,ITS ONTIME SCAN AND WORKS LIKE A DREAM.
FREE ON THE NET
Jul 04, 2009 | Acer Aspire One PC Notebook
Acer Aspire One A150-1006 Notebook Logo
216 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
