Question about Safe T Alert Carbon Monoxide Alarm Rv Trailer
Same alarm problem setting offf
My C-Class motorhome is parked in my driveway, with no car or engines running around. The alarm sets off here and then and I cannot figure out what triggers it! I must say that it is very damp outside (fog in the morning and drizzle during the day. Could it be the problem? Solution, please.
Thanks
HHambly
    Scholar:
  • 43 Answers
As a camper myself, I know that one of the last thing we check is our Carbon Monoxide detectors in our unit. I had an old Class C motorhome with a CO detector that failed to alert me, and my kids got to the point of being nauseous. We were lucky to discover the problem.
A Carbon Monoxide Detector needs to be changed after 5 years because the sensor is designed only to last this long. If your unit needs to be changed, you can shop online on my website http://carbonmonoxidedetectoralarms.com/
Good luck and happy trails.
Posted on Jul 29, 2010
93 Georgie boy Cruisemaster motorhom 93 Georgie boy Cruisemaster motorhome stuck in park i 93 Georgie boy Cruisemaster motorhome stuck in park any ideas on how to fix
As with most cars and trucks, if the shifter won't move out of park, one possible cause is a faulty brake switch or shift lock solenoid.
If the RV is on flat ground and the park pawl is not under heavy load, you may be able to shift out of park by unlocking the steering wheel but not turning the key to the on position. Make sure the parking brake is set before you try it.
Sep 18, 2015 | Cars & Trucks
Problems diesel starting
You will have to unscrew the fuel filter and fill it up and prime system!
Apr 06, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
I have a 1999 Damon Challenger class A RV, that the heater just blows cool air, but it isn't the heater in the engine, it is the heater in the living area. I am parked and hooked up to hook up's. the...
Does that heater have a pilot light or is it electric start? Look at the ignitor while turning it on and see if it sparks.If it doesn't , it's probably bad. If it does but doesn't light, the ignitor isn't opening up to allow enough gas to get through to ignite.
Oct 29, 2013 | Rv Motorhome Dual Co & Lp Gas Alarm...
1998 P30 Chassis with locked brakes in driveway
Some chassis had a central parking brake that was a drum
inline with the driveshaft. This brake was actuated by use of a cable to the drum. Some units had the cable running to close the the exhaust manifold which caused the shield
around the cable to melt thus locking the cable in the last
position before the plastic set up after cooling. Only way to
correct was to replace this entire cable and rout the new one far enough away from the exhaust heat to prevent
occuring again. You did not mention what kind of parking
system you had. Parking brakes are all mechanical. Even air brakes. They are held open with air and lock up when
air is removed.
Feb 07, 2018 | Cars & Trucks
I just had a fuel pump replaced on a 2000 23' Class C motorhome with a Ford V-10. It cost me approx $1400. The mechanic claimed the fuel pump was a special order item from the dealer for motorho
Don't know what the problem is here...nothing stated. 1400 for a fuel pump repair seems a bit high but I don't know what the part cost is. I am just throwing out a ball park here (without ever having worked on the particular vehicle) but i would say this would be estimated at about a 4 hour job. Shop rate probably 90 to 120 so on the high end for labor 480. Now check on the price of the fuel pump. Check online sources such as Carquest, Napa or ORielly.
Jan 31, 2013 | Ford F-350 Cars & Trucks
I have a 1998 Old Aurora. The car was parked in the driveway for over two months. The parking lights started to flash while the engine was not running. When I unlocked the car, there was a clicking...
I would say that the battery is low from sitting. Some alarm systems have a low voltage indicator that sets off the alarm. The flashing lights and clicking (alarm module) under the dash are indicative of just such a problem. Have the battery charged and consider disconnecting it or you can purchase a solar charger that plugs into the cigarette lighter to keep the battery charged (usually under $30 @ Lowes). However if you remove the battery is may you to lose radio codes etc... I believe the solar charger is the best option at this point. Have someone give it a boost with jumper cables or a charger to stop the flashing and clicking in the interim. Thanks for using Fixya and please post a comment and rate my assistance.
Jul 21, 2011 | Oldsmobile Aurora Cars & Trucks
RS4 performance chip in a 2008 Class A motorhome
RS4 performance chip is just a $0.50 resistor that fools your IAT (Intake Air Temperature) sensor. All it will do is cause your engine to run leaner or richer depending on what the resistor rating is on the resistor. You can get the same result by disconnecting the wire leads to your IAT, the resistor only keeps your check engine light from coming on.
The higher resistor rating, the leaner the engine will run and the lower the resistance will cause your engine to run richer. But the program to your engine PCM has set perimeters which takes readings from your MAF, MAP, Engine Temperature, and O2 sensors to keep your engine running at 14.7:1 air fuel ratio, so the RS4 Performance chip only works during start up on a open loop with the engine still cold and under 400 RPM. It IAT is only there to determine the amount of fuel needed to start the engine during cold starts.
If you are interested in a true performance and economy for the amount of fuel used. Dyno tune your PCM for the best performance your F250 can provide.http://www.pcmforless.com/ is one of the best tuners out in the market that is worth investing.
Thank you for using fixya, and good luck
May 10, 2010 | 1984 Ford F 250
My mercedes c240 will click but wont start
My Mercedes C-Class 1996 won't start up, the alarm is confused it thinks it's locked, every time i unlock it, the red light( locked) and green light(unlocked) flash at the same time constantly, if I open the car and try turn on the engine, the alarm starts blaring, I've turned it on before and drove it around but when i came to park it up it did not turn on again because of that problem.( The car hasn't been touched or used for a year before i got it going again)
Apr 09, 2010 | 2004 Mercedes-Benz C-Class
Why does my alarm go off when its just sitting in the driveway and nothing around it?
factory alarm? my personal truck has the same issue but in my case when i set the alarm after a while it will go off. what i found on mine is my door sags because the bushing in the hinges are worn and with it sagging the swich in the door that controls the door ajar light is not setting where it should so sometimes it would send a signal that the door is open which sets off the alarm idk this may be the same with yours.
Oct 22, 2009 | 2007 Chevrolet Silverado 1500 2WD
I have a Class C motorhome. The unit is in storage and when I arrive to check on the motorhome, the alarm is going at low alarm or needs replacing noise. I had the unit checked as well as the motorhome....
hi chuck. the source of the carbon monoxide is outside of your unit. for example other engines running near by sending fumes into your unit and setting off your alarm
Jun 25, 2009 | Safe T Alert Carbon Monoxide Alarm Rv ...
Safe T Alert Carbon Monoxide Alarm Rv  Trailer Logo
431 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
