I dont have instructions
Turn the unit off by pressing and holding the volume button till it powers down (NOT VIA THE IGNITION SWITCH!) Once off, press and hold the fuction button (located in the top left hand corner near the volume dial) until unit lights up again and a menu appears, the clock settings should be the first option available
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour-Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
put a clock right.
Note
You can match the clock to a time signal by
pressing MULTI-CONTROL.
! If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes 10:00.)
! If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
Here is a link to the online Manual: http://a248.e.akamai.net/pix.crutchfield.com/manuals/130/130dehp690.pdf
