Question about Lexmark X83 All-In-One InkJet Printer
I've bought new cartridges but the printer is printing blank.
    New Friend:
  • 63 Answers
Remove the cartrideges and check for packing material ... find the intructions and follow them carefully .. GOOD LUCK !!
Posted on Jul 02, 2009
Brand new printer with brand new ink prints BLANK pages
Hi Mike This is an odd one. If it prints the bars then ir should print everything else - cleaning is just wasting ink in this case.
I'm guessing that this is still under warranty, so I would take it back and get it replaced.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Problem with my PC cant get mky printer to printer more than blank pages. Just bought new ink cartridges
Before fitting new cartridges and before removing them from their packaging give them a good shake.
If you think you have blocked nozzles stand the old cartridge in warm water.
Oct 22, 2012 | HP Officejet 6500 All-in-One Printer
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
I have try to print but its not printing. i've allready fill the ink still the page come out blank.
It could be due to the refilled cartridge that you are using. Refilled cartridges tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. Please follow the steps below to fix the problem:
  1. On the printer control panel, press Copy.
  2. Press Options until Maintenance is highlighted.
  3. Press the right arrow until Align Cartridges or Clean Cartridges appears, and then press Select. A test page will then be printed forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the cartridges are working.
If that doesn't help, I would suggest you replace your cartridges with new genuine Lexmark cartridges.
Aug 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
Will not print its saying the wrong cartarige
Each printer has its specific print cartridge. If you've just replaced the print cartridges make sure the number on the new cartridges matches that of the previous cartridges. The printer will reject the cartridges if they are not of the same number even if it is different by one. It is advisable to provide complete details of your printer including type and series when you purchase cartridges for your printer. Hope this helps.
Jul 04, 2011 | Canon PIXMA MP780 All-In-One InkJet...
All the pages I print are blank. There is sufficient ink the print preview shows the image but the actual print out is blank
Sounds like your print heads are clogged. This is quite common. Go into your printer's menu and find the maintenance menu and follow the steps to clean your print heads. Run the process everal times until the prints are 100%. Then run a printhead alignment. Regardless of whether your not your ink is full, if cleaning the heads several times does not solve the issue, put new ink cartridges in because you may have bad cartridges. If that doesn't work, you've got bigger issues, contact the manufacturer.
Apr 26, 2011 | Office Equipment & Supplies
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
Printing out blank paper
Under your windows did you check at the printer settings.. maybe you set it to print with the color cartridge only and now its empty. Check and set it to use black cartridge.
Jan 04, 2009 | Lexmark X83 All-In-One InkJet Printer
Blank ink is not working even bought new cartridges
Dear keogh,
What's model of your printer ?. As my experience, print blank may have some possibilities Here are:board is faulty, purge unit not function properly, or print head is faulty. If say that you just bought new cartridge, so it may board or purge unit of your printer in problem.
I suggest you to take your printer to nearest service center. Hmm, before that you can try clean the print head in printer driver properties first.
Regards
Source:
IJ Forum
Nov 27, 2008 | Office Equipment & Supplies
Lexmark X83 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
