Question about Zoom H4 Handy Recorder
H4 zoom battery operation
My H4 zoom will not operate on batteries. It operates fine on AC adapter.
The H4 will not power up in battery operation. It appears dead. I have replaced batteries and problem still exists.
    Problem Solver:
  • 17 Answers
Try resoldering the circuit board where the power socket is ... as there is a switch on the socket that disconnects the batterys
Posted on Jul 17, 2009
  • playD May 18, 2012
    I have the opposite problem -- my H4 works perfectly on battery power, but the power adapter does not work. I have a friend with an H4n whose specs indicate the same power requirements (12v 1amp -ve polarity) -- we tried his power adapter with my H4 -- it still does not work on AC power. My friend checked the connections and they all seem fine otherwise. His suggestion was to solder a jumper wire from the AC connector to the battery side and use a 3v adapter instead, but not really interested in doing so. It would allow me to run the unit on AC, but my real interest in running it on AC is to use phantom-powered mics for extended periods of time. Any ideas?
  • Michael McLennan
    Michael McLennan Jan 18, 2013
    I think it must be a problem with the H4,,, mine won't seem to run off either adapter or batteries, however when I put rechargeables in at 2.6v combined it will run and then power down stating that it the battery is down!?!. I have tried to hardwire and run off 3v like in the above suggestion, but doesn't seem to run then either. My guess it is a known voltage sensing issue with the unit.
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
What would cause my Zoom HN4 not to power up from batteries or mains adapter?
You will probably find the bottom board (the one where the inputs go) unplugged from the Main board.
Clean connectors with alcohol, plug back in, and in my case I put in a toothpick to maintain pressure to the chassis. BINGO ! You might check the other boards too and clean battery connectors. Be Happy and Well....
Jun 26, 2014 | Zoom H4 Handy Recorder
How to perform a factory reset on zoom H4
Hello ! Actually what you do is download the latest firmware from the ZOOM page. Find HANDY H4 (you can Google that) and go to the Download tab. Follow all instructions. Be sure to have new batteries or be plugged in to AC while you reset. I've done it on my H4(I have 2) and H4n and it worked fine. Be patient, it takes a while once you start. Good luck !!
Mar 09, 2014 | Zoom H4 Handy Recorder
It blinks with "be" and turns off
It may be "but" that you're seeing, which indicates the batteries are low. Use the AC adapter made just for this model only, and the guitar needs to be plugged in to turn the unit on. A full manual for this Zoom model can be found here:
https://www.zoom-na.com/sites/default/files/products/downloads/pdfs/E_G1_G1X_3.pdf
Dec 01, 2013 | Zoom Samson Technology Zoom G1XN Multi...
My zoom g1x displays BT even though i don't use any batteries for it
You need to replace the power resistor R54:
http://gisywall.blogspot.it/2016/01/zoom-g1xn-continuously-shows-bt-on.html
Sep 28, 2012 | Samson ZOOM G1x Guitar Effects Pedal
I was using a universal AC/DC adapter with my Boss MicroBR, and when I powered it on there was a small plume of smoke. Now it won't work with any AC adapter. I hate using batteries, because it drains a...
Rechargeable batteries CANNOT be used in this, ONLY alkaline batteries. Rechargeable batteries are ACTUALLY lower volltage (about 1.25 instead of 1.5) that is very near the cutoff point for operation so even fully charged rechargeables last only minutes. Sorry you used "universal" adapter because either you chose wrong polarity or too high a voltage and fried the internal voltage regulator. It is repairable by repair facility.
Jul 11, 2011 | Music
Hi! I placed a bid on Ebay, on a used Zoom H4 and didn't read the fine print! I now notice that the seller says that the condition is good, but the battery operation doesn't work - it only works with the...
Usually the problem will be with the battery contacts. Often corrosion due to leaving batteries in too long or the spring contacts, don't. Another harder thing is the adapter connector often has a spring blade that contacts the center pin when adapter is unplugged to switch to battery. These get bent and are a chronic problem for devices that use either adapter or battery.
Apr 13, 2011 | Zoom H4 Handy Recorder
My Zoom H4 will no longer run with batteries. If I use AC adaptor it works fine but I get nothing on battery power
Probably the connector where you plug the AC adapter into has a switch contact that disconnects the battery when external adapter is used and it has gotten bent so when the adapter is not plugged in, it no longer makes contact to the battery power. This is pretty common for devices that use both battery and adapters.
Aug 23, 2009 | Zoom H4 Handy Recorder
Zoom H4 recorded data disappearing
I have a H4 but not that problem. Have you tried recording when the H4 is charged? My guess is when low on battery, the H4 doesn't record.
Sep 02, 2017 | Zoom H4 Handy Recorder
Zoom H4 does not power up on battery power.
Probably two years too late, but I recently got a used H4 and it was having this same issue. Upon reading the documentation, it seemed as though it required a specific type of AA batteries. If you update the firmware (mine was 1.3) to the latest version (currently 2.4), you can toggle the battery type under the menu (most likely alkaline is what you want). It also added lots of other great features!
Jun 02, 2009 | Zoom H4 Handy Recorder
Zoom H4 Handy Recorder Logo
434 people viewed this question
Top Zoom Music Experts
Michial Gueffroy
Tom Chichester
rhodesworks
Are you a Zoom Music Expert? Answer questions, earn points and help others
