Question about Honda Garden
Broken choke control on snowblower
I have a honda hs 20 snowblower. The choke seems to be broken. When I look underneath I see that the choke control knob is not connected to anything underneath. Do I need new parts, or can I fix this myself? What does the choke connect to? ( sorry its in the wrong category, but there is nothing for snowblowers here......)
  • 211 Answers
Hi jared
the chokeis connect to the carb.it opens and close the trottle.try to locate where to connect the cable to opperate the trottle
bye
Posted on Sep 23, 2009
Had trouble starting the snowblower but when it finally started...it went straight to about 3,000 rpms and I thought it was going blow up. I pushed the choke in and it went faster.
Sounds like the springs on the carb have either come off or broken or got caught on something. Don't run this way or it will ruin it.
Dec 13, 2016 | Garden
I have a new, first s ason and broken in 20'hp honda outboard. Full choke fine starts first pull. After warm up and leaving at dock for 20 minutes it restarts hard with and without choke
Hi Ira:
Honda's are notoriously reliable, so, since it is a new engine, I'd be heading straight for the shop where I purchased it.
From personal experience, every one of the different pieces of equipment that I own has slightly different starting characteristics.
Once you determine the "routine" for your outboard, it should work the same way, every time.
Jul 15, 2016 | Honda 20 HP Engine - GX630RQXF6
I have a honda snowblower SZAN-1131370 how can i stop the back firing it starts up ok with chock on but when i shut choke off it seems to backfire does the air needle valve need to be adjusted
Carburetors never need to be adjusted once they have been adjusted at the factory UNLESS something is not right with the carb.
If the gas has been in there since last season I suggest you take the bowl off the carb and see if the Ethanol Gas caused the internal parts to rust. Ethanol gas is a very bad idea that the politicians forced on us without considering the affects
Nov 23, 2014 | Honda Carburetor for HS520 Snowblower
Sovereign strimmer HS-PT-2538
I had this problem once when machine was hot it was difficult to restart, I've found putting choke on slightly, about a quarter of the way, and not touching the throttle will see it starting, then put choke back off and leave it to idle for 20 - 30 seconds before using. Seems to be a characteristic of this strimmer.
Jun 11, 2013 | Garden
Auger in snowblower blower does not turn
Check to see if cable is still ok and not broken. Also adjusted.
Feb 10, 2013 | Craftsman Snow Blower / Snowblower Bottom...
1983 Honda Shadow Spirit 750 backfires
Hi, Jstevens47 and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
9. Improper valve clearance (too tight).
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
why is my bike popping backfiring
Backfiring How to fix
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Sep 20, 2011 | Honda Shadow Spirit 750 Motorcycles
Nokia HS-20 AD-41 broken who can repair please help me with a diagram
If the wires are open or the connections are visibly broken then the connections can be mended. But if there is fault in the earpieces then I suggest that cost a new one must be checked before you think of getting this repaired.
Mar 14, 2011 | Nokia Music Headset HS-20 & AD-41 Headset
2006 Honda ANF125 Innova misfire at idle
Hi, Desobrien and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor contaminated, sticky float, plugged jets.
13. Carburetor has oil in the bowl due to excessive oil in pre-mix.
14. Carburetor vacuum diaphragm torn, cracked, not seated or installed improperly.
15. Multiple carburetors out of sync.
16. Fuel filter clogged.
17. Old or contaminated fuel.
18. Fuel tank vent system plugged or carb vent line closed off.
19. Gas cap diaphragm valve faulty.
20. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
21. Carburetor controls misadjusted.
22. Incorrect valve timing.
23. Valve springs floating, weak, or broken.
24. Damaged intake or exhaust valve.
25. Incompatible performance parts.
26. Control module may be in "LIMP" mode
27. Check for engine trouble codes.
Symptoms of Lean or Rich carb settings on motorcycle
rough idle CBR Forum Enthusiast forums for Honda CBR Owners https://haynes.com/en-gb/honda-anf125-innova-scooter-03-12-haynes-repair-manual $20
Honda ANF125 Owner Manual
May 31, 2010 | 2006 Honda ANF125 Innova
Honda snowblower problem
yes you can adjust the throttle cable, did you leave gas in it over the season, if you did this is definitley the problem, dump out the gas and pour new.
Feb 25, 2009 | Garden
Honda snowblower engine hunting
Sounds like you are hitting the governor. Watch the arms at the carb when you move it to full throttle. The arm should hit a screw. Turn this screw clockwise, until the reving stops.
Dec 08, 2008 | Garden
Garden Logo
279 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
