Question about Bosch Washing Machines
We bought our Bosch confort 6 water heater in Mexico and we do not have a english manual. Please tell us where we can find one. Belle Marie
Hi Belle Marie, I too am in Mexico with a Comfort 6 which I can not get to function. I found no tech support on line and as I am quite remote, don't want to bring it back to Home Depot Vallarta and let them hang on to it for months. I'm pretty handy but would like to find troubleshooting hints, either in English or Spanish. Anybody?
Posted on Jan 08, 2011
Bosch Confort S 13 BP tankless water heater won't ignite, It clicks but no gas going thru valve
The S 13 BP is a simple unit that does not have a pilot light. It uses electronic ignition on demand, which is what you hear clicking. If there is no gas going through and you've verified there is gas to the inlet, then it has to be the gas control valve.
Feb 01, 2013 | Bosch & Tankless LP Hot Water Heater
Need manual for MT9701S
Need English instruction manual for MT9701S refridgerator.. bought in PV Mexico for condo... need "english" manual please
Also need "english" manual for LG MS1146SQP for year 2008 microwave oven also bought in PV Mexico
Thank you
Jan 17, 2013 | Maytag Refrigerators
My Ariston 4 gallon water heater is given out hot dirty water?... Any Suggestions?
1) Dirty water implies degraded metal inside unit:
The anode rod protects metal parts. Once anode is depleted, metal parts react with water.
2) Open following troubleshoot pdf showing Ariston parts
http://waterheatertimer.org/pdf/How-to-Troubleshoot-Bosch-Ariston-Water-Heater.pdf
3) Ariston manual: Read manual cover to cover, make sure water heater receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
4) Information on anode rods
http://waterheatertimer.org/Replace-anode-rod.html
5) For Bosch gas and electric tankless: Open following link for troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
6) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Bosch Ariston GL4 GL4 Point-of-Use...
I have a Bosch confort 13 tankless water heater in my Mexico home. I have had problems with consistent water temperature. My contractor told me they have problems with them down there...not sure if it...
Your contractor understand the market there, but problems are mirrored in US also.
As evidenced by fixya.
1) Tankless cannot be exposed to more than 11 grains hard water, and require minimum water flow and water pressure or sensors will shut down burner or element.
2) For example, tankless might turn on with 2/3 gallon-per-minute water flow, but then another faucet is turned on so pressure and water flow drop, and tankless turns off. Or neighbor's water usage causes decrease in line flow, so tankless turns off. This is called 'cold water sandwich.'
3) If problem is water pressure, you can add in-line pressure tank, but root causes vary widely with more than one factor as suspect.
4) Also incoming water temperature can be a factor, along with temperature setting of unit. Most tankless are preset to 120 degrees F, which is modest temperature and certainly not very high. If tankless cannot raise temperature of incoming water fast enough, then tankless turns off. Of course water flow continues, so you get dose of cold water.
You can add simple120Volt 30 gallon tank-type electric heater as a tempering tank that pre-heats water either passively or actively: http://waterheatertimer.org/Tempering-tank.html
5) Both internal and external factors affect tankless, with bottom line that these high-tech devices are not do-it-yourself repair for most people.
6) Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
7) In my opinion, the genius of tankless is not that they save money or energy. Because they don't.
The genius is marketing that targets a certain affluent who believe tankless save money and energy.
http://waterheatertimer.org/pro-n-con.html
Add a comment for more free help.
Mar 22, 2011 | Bosch Water Heaters
Bosch tankless hot water heater: Confort TOO HOT!!!
Look for a water temp control on unit. Otherwise a lower temp can be attained by having a higher water flow to minimize temperature buildup in heating coil.
Sep 06, 2017 | Bosch & Tankless LP Hot Water Heater
Instructions for my Ideal Mexico CF60P Propane boiler
Hi tessajoe,
I'm Harvey, the master plumber. You asked where you can
download instructions/user manual/installation guide for
Ideal Mexico CF60P Water Heaters. I believe this is the correct link:
http://www.chspares.com/partselect.php?test=121
Some Companies will e-mail it, others will respond if you call them on the phone and they will fax it or mail it. Contact info on the link that you requested form me.
I'm happy to help you!
Feel free to contact me.
Harvey the Master Plumber
Sep 07, 2008 | Water Heaters
Bosch dishwasher
If you telephone Bosch on
08705 678910 they will be able to send one out to you
Hope this helps
Deep Diver
Jan 10, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Washing Machines Logo
269 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
