Low air flow on ac and heat on 2001 dodge durango
  • 400 Answers
This can be caused by a clogged evaporator. Cleaning a clogged evaporator is best left to a professional
Posted on Jul 02, 2009
  • Shane Seaman Jul 02, 2009
2001 Dodge Durango front and. Rear heat front floor no heat
http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?fromSearchPage=true&pageId=0996b43f80375f32&partName=Timing+Belt+Cover,+Belt+&+Sprockets&partId=0996b43f80375f32 SAVE 20 GET 10 GIFT CARD ON ONLINE SHIP TO HOME ORDERS OF 100 OR MORE
Nov 06, 2015 | 2001 Dodge Durango
I have a 2000 dodge durango 5.9 L and the temp almost reaches 210 the heaterblower,blend door and ac work but not heat to the cab whats the deal could it be air locked in the coolant ???
it could be an air lock causing the high temperature and low heater heat
it could be no water in the radiator
it could be a blocked heater core
Oct 13, 2015 | Dodge Cars & Trucks
Where is the orifice tube on a 2001 dodge durango
Not positive, but probably inline in the high pressure tubing.
Jun 17, 2014 | 2001 Dodge Durango
My rear ac has been disconnected and lines sealed up i still have no front ac 2001 durango
What Pressure are you showing on the High Side and Low Side respectfully on your Gauges?
Apr 04, 2013 | 2001 Dodge Durango
2001 dodge durango 4x2 with ac on, hot air blows out of driver side vents and cold air blows out of passenger side vents
There's a small motorized flap that's controlled by the heating and ac system that's gone bad. This part changes the air to flow from the ac or heating side depending on settings. I had a 1999 Jeep Grand Cherokee with the same issue, the fix is relatively simple once you get to it, however you must completely remove the dash to get to the part. The part is about 15.00. When removing the Dash you MUST disable the air bags, if you do not you risk injury or death if they are accidentally deployed.
Feb 25, 2013 | Dodge Cars & Trucks
2001 Dodge Durango 4.7L 4x4. A/C is on but no air
Check the resistor pack next to the air motor blower, after you check the fues's the resistor pack is most likely blown but to be sure turn it on to heat and try the blower motor if it still does not run remove the restior pack and look and see if they are burned out, it will look like a fues thats blown. Two 1/4 screws holds it on and has 4 or 5 wires in it. If you need more help please post here.
Sep 05, 2009 | 2001 Dodge Durango
No rear heat
The rear vent system has a separate heater core/blower system. heater core could be plugged up or the coolant lines going to rear heater core are plugged. could also be low coolant/faulty water pump not producing enough pressure, or air in the cooling system which will need to be bled if so.
Feb 22, 2009 | 2001 Dodge Durango
Heating & Cooling Logo
150 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
