Question about Philips 42FD9932 42 in. Plasma Television
Start-up relay not locking in.
Please can you with this problem? I have a 42 PF9964 Philips plasma.
After turning on a relay is heard bouncing on and off and the green light pulses on and off with it. I am feeding a VGA signal into the VGA socket.
This problem has been getting worse for some time and today the relay just will not lock in.
I am fairly technical and probably could replace the relay if I could identify it.
Many thanks.
  • Anonymous May 12, 2008
    I have a philips 32fd995417s that has the exact problem. What are 4pin IC's?
  • Anonymous May 18, 2008
    Few months now tv had to "warm up". Would repeatedly click and eventually come on. Now when you try and turn set on, red led light on monitor goes out for a few minutes then back on. TV still not coming on. model 42fd9932...
  • 149 Answers
Don't think is relay problem you may have dry capacitor in the star up circuit of your power bottom part of power supply is some 4 pins IC,s around are some 2.2 4.7 @ 25 volts replace them ..had same problem
Posted on Apr 09, 2008
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Can't get the start-up menu to close on my phillips plasma
Try downloading the latest software for the TV at the philips web site.
This solution worked on most of the Philips TVs that had the same issue.
I hope this works. Please rate me. :)
Mar 07, 2009 | Philips 42PF9630A 42 in. Plasma Television
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
My philips 42 inch plasma model # 42PF9966/37 wont turn on. Red standby light is not on
Hi. Try, in back yours tv on left side of the power corde connector have on hole, inside of this hole have one main switch, using one insulated stick and sheck if this switch is off ( may be not ) but try. If you heva esperience take out the back cover and check the fuse on power board. Good lock
Jan 03, 2009 | Philips 42FD9932 42 in. Plasma Television
42FD9954 philips plasma TV flashing LED it wont come on
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Nov 08, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Any ideas?
1) Replace C2663 by 2020 021 91677 (100uF/50V, 105°C).
2) Place Schottky diode 9336 247 60133 on pin 7 (+) and 8 (-) of IC7650,
to avoid negative pulses, resulting in this bad startup behaviour.
Mar 25, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Philips plasma won't turn on first time
I have found this on a site and am in the proccess of trying to mend my plasma PF9964 as it started to take longer and longer until it stopped coming on. I've got the back off so I just need to un solder capacitors and replace. Here's the info I found. Bad power switch circuit General Comments If you have this problem with your Philips 32PF9964: When I switch the TV on, it appears as though it is going to start i.e the green light comes on, then after about 10 seconds it switches itself off and the standby light flashes red. It takes 10 /12 times before it starts and is getting worse. This is the solution: The problem is three caps. Change the cap 2663, 2664 both 100µ/25V and 2662,1000µ/25V. After you have changed them your TV will work again. You will find them easy if you unscrew the back on the plasma TV. Cheers, Mike
Jun 26, 2006 | Philips E-Box FTR9965 DTV Receiver
Philips 42FD9932 42 in. Plasma Television Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
