Question about Samsung ML2250 Laser Printer
On line/erro light is on
The machine is not printing and if i want to repair the solve wear it when i connect it keeps on telling me to connect the cable meanwhile the cable is well connected. so i tried with this cable number too EEE Parrel cable still they say the cable is not connected please tell me what to do
    Problem Solver:
  • 10 Answers
Replace the fuser
Posted on Jul 27, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Canon BJC printer keeps printing test pages
Printers with USB are so inexpensive and think you have an incompatibility issue with your BJC-80 and the usb to serial convertor is not helping.
http://www.ebay.co.uk/sch/Printers-Scanners-Supplies-/171961/i.html?_from=R40&_nkw=printer&_sop=15
Hope that helps.
Mar 19, 2014 | Canon Office Equipment & Supplies
Ltf700es1 erroe ebf ?
EBE and EBF are console control problems. This error could be solve replacing the control board, rewiring, or replacing this part on the washer. It is always best to consult or hire a professional when you want to repair an appliance.
Hope this helps; just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Jose.
Oct 17, 2011 | Frigidaire ATF6000ES Front Load Washer
My laptop -e528-2325 keeps telling me check cable connection! Then operating system not found? ??help me please? ??
Maybe you cannot solve this on-line. Fist check the boot sequence in the Bios and put that to the first hard disk noramaaly coded with zero
Next try to repair the master boot record
also what you can do is remove the harddisk and reseat it. If that all fails you need to open it and if you have never doen that you need to consider if its worth to seek technical advice.
goodluck
rene
Jun 08, 2011 | E-Machines Computers & Internet
Im using canon mp145 printer.i have problem when i want to print out.the erroe was the ink absorber is full.how can i solve this problem?
The only way to correctly repair this fault is to service the machine
waste absorber pad needs to be replaced.
the waste absorber counters need to be reset
Feb 15, 2011 | Office Equipment & Supplies
Orange light keeps coming on and I cannot print anything. It gives an alert on my lap top to say USB non compliant. Canon ip 100 series. A non compliant device is connected to the direct port or...
try removing the camera software that was presumably installed.
If not, can you try a System Restore? Sys Restore will restore your laptop to an earlier time. Try a restore date prior to the date the problem first occurred. (Sys Restore in WInXP is accessed thru Start/Accessories/System Tools- Restore dates that you can use will be in BOLD font on the calendar)
Cheers,
Steve
Jul 11, 2010 | Canon iP100 Portable Printer
Keep getting 5100 error message--eratic
PLUG IT OUT FOR ABOUT 3 DAYS.AFTER PLUG IT BACK IN AND IF YOU ARE STILL GETTING ERRO MESSAGES CALL 2489921 OR 2849921 AND I WILL GET YOU SOME ONE TO SOLVE YOUR PROBLEM.
Dec 15, 2009 | Canon MP610 Photo All-In-One Printer
I cant get my printer to clean or print keeps saying unable to print, please help
verifiqure se da algum erro
se der o erro:machine error xxx
faça o seguinte:
May 15, 2009 | Brother MFC-215C All-In-One InkJet Printer
Bauknecht wa3000
please send me the steps that i have to follow to solve the
fault 07 that i get at the end of the program
Thanks.
George
May 12, 2008 | Washing Machines
Samsung ML2250 Laser Printer Logo
162 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
