Question about GE (PSS26MSRSS) Side by Side Refrigerator
Jenn Air refrigerator JCD2289AE Freezer cold Refrigerator warm
What has been done over the last two days: Cleaned condensor totall blew out bottom area Fan relay is working as is fan motor on condensor have not accessed any other area under refrigerator section but as near as I can tellis it is clean.
First and second day freezer is at 19 degrees at the top
refrigerator 60 degrees. No apparent change. controlls all set on coldest. Suction side cool/pressure side is about 115 degrees or less.
  • 583 Answers
Check out the timer in the unit.its located beside the compressor fan.as the timer controls the heat and cold ness in the unit.if the timer is is not moving at its regular speed the coldness will get too much in the upper side and it will go increasing and defrosting procedure will not start as per the system.in your unit the timer needs to be checked and replaced.the cost of new tiomer assembly will be near to $40 you can get it at www.repairclinic.com also at www.partselect.com thanks.please do rate the session.thank you for using fixya.keep updated.
Posted on Jul 02, 2009
Hello, my LG Refrigerator (lmx28988st) is acting up. The fridge stays cold, but the freezer won't freeze (its stays around 45F). It has the french doors for the fridge, 2 drawers for bottom freezer.
Have you confirmed the freezer door switch is functional? If this switch fails to detect the door is shut (you may or may not get an alarm), the unit will fail to cool properly. Meaning the actuator will not allow cold air to be diverted to the freezer.
If all else fails, you may try contacting LG directly by clicking here:
LG Get Product Support LG
Feb 17, 2018 | LG Refrigerators
Jenn-Air JCD2389GES problems
The condensor fan cools the condensor coils. If it is running this will cause a no cool situation. Also, if the condensor coils are plugged with dirt that insulates the coils and causes a no cool situation. These things will make it so the freezer isn't cold enough to freeze water so the icemaker will not produce ice. As far as the door edges getting hot. A condensor line runs thru the cabinet between the doors and this is called the mullion. If it is too hot this is a good indication of a bad condensor motor or dirty coils. Clean the coils and check the status of the fan motor and let me know what you find and we will see if we need to go further.
Nov 11, 2007 | Jenn-Air JCD2389G Side by Side...
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
Freezer is cold but refrigerator is warm. What do I check?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 31, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
Refrigerator starts off cooling after a while starts blowing warm air cleaned off condensor coils very good. cooled for a day and back to warming up what could be the problem?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 05, 2010 | Frigidaire FRT21H8 Top Freezer...
Refrig/bottom freezer not cooling, fan running, lights running, controls working fine, every 5 minutes a humming, then a clicking....cleaned condensor fans and cleaned condensor coils by vacuuming My...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 30, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
The drain pan in the bottom of a jenn air refrigerator
Remove the 2 screws , holding the freezer panel on , to gain access to the drain . The pt number for the housing is 61003830 . You may have to remove 2 screws to remove the housing .
Nov 11, 2009 | Refrigerators
Everything in My Freezer is Melting and Fridge is getting warm!
find another place for all of your food because you may need to call a service company.
possible causes: stuck in defrost (if nothing is running) bad compressor (if fans are still running) freon problem if everything is still running
Jun 28, 2008 | Jenn-Air JCD2389G Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
