Question about Fuji FinePix S1000FD Digital Camera
Fujifilm S1000fd - flash not working
Even when the flash is popped up, the "no-flash" icon is displayed under all settings. Pressing the "flash" button on the back of the camera does nothing.
zohail
  • 1223 Answers
SOURCE: will not take pictures fujifilm finepix s1000fd
it seems like CCD failure rush to service centre
Posted on Feb 20, 2009
SOURCE: My FINEPIX s1000fd fujifilm camera
Try these:
1) Make sure the lens cap is off. When the camera fires up, if it feels any resistance, it will stop zooming and tell you "zoom error"
2) Recharge or fit new batteries. Use 2700 power if you can get them.
3)Is there a bit of dirt between the zoom part and the camera body? I had this problem after my camera had been in my overcoat pocket. I cleared it out with a stiff artist's brush. Do NOT use WD 40 or similar, as I found to my cost on another camera. It eventually seeped through to the works and made all the pics cloudy!
4) Hold the camera body in one hand and gently wiggle the zoom part from side to side and up to down.You will hear a quiet click in the mechanism.
I have used my S1000fd lots now, and the initial "zoom error" problems have stopped.
It's a fine little camera, I especially like the 12x zoom and the live histogram. Mine has taught me lots about photography.
Posted on Apr 01, 2009
zohail
  • 1223 Answers
pls update firmware issue will be resolved most likely and pls rate me fixya for help
http://www.fujifilm.com/products/digital/download/s1000fd/fupd.html
Posted on Apr 13, 2009
SOURCE: Fujifilm FinePix S1000FD shutter button won't focus
There is an option in the menu to put camera on continuous auto focus. You must have the camera on manual setting to have this option available, but once selected, it should stay on in auto setting. It will wear the battery faster, but it should solve the issue you are having. Hope this helps!!!
Posted on Aug 16, 2009
Testimonial: "Luckily the camera was still in warranty and I sent it off to Fuji to get it repaired. It came back and they had replaced the shutter button. Thanks!"
lock123
  • 6831 Answers
SOURCE: My FINEPIX S1000fd fujifilm camera
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 21, 2010
How can i fix my fujiflim flash?
If you bring it into an authorized Fujifilm repair center found on the Fujifilm website or to a local camera repair store. Since the camera is still operational, you might just need to have the flash bulb replaced...
thanks.
Apr 11, 2011 | Fuji FinePix S1000FD Digital Camera
Have a fujifilm finepix s1000fd and when I use
Your cameras focus lens is probably stuck.
It operates via a long metal rod, a pin which follows a track in the side wall of the lens and a tensioned spring. one or more of these has probably jammed causing the focus lens not to move when you zoom.
Unfortunately for this camera, if you cannot free it by switching on/off, tapping the lens etc, you will have to strip the camera down to get at the lens unit. you will have to discharge the flash capacitor before desoldering the control board from the main board before removing to access the lens.
Recommend you find someone who knows about this or send to Fuji.
Apr 05, 2010 | Fuji FinePix S1000FD Digital Camera
I cannot get the flash to work???
the flash is a pop-up mecanizem. on the left side by the neck strap ring, theres a little button. that button should pop the flash up. and there ya go. on some settings the flash doesnt work even with the flash up. on the screen, when its on theres a little lighting bolt, when theres a line through the lightning bolt, that means flash is off, when you have it on the AUTO setting and its fairly dark out, and the flash is up, it should automatically be on. anytime you see that lightning bolt on your camera, its related to flash.
Jan 31, 2010 | Fuji FinePix S1000FD Digital Camera
Everytime i use the flash on my Fine Pix s1000fd it freezes
Some SD/HC cards will cause this problem.
You need to upgrade the firmware to version 1,05.
Best regards
Peter Schroeder
Sep 22, 2009 | Fuji FinePix S1000FD Digital Camera
My son has a Fujifilm S1000fd and when I get the pictures printed, there is a yellow hue in the photo, how can I fix it?
Color setting on the camera. Is it set to Auto White Balance (AWB)? Daylight? Fluorescent Lights? Flash? Cloudy Day? It's best to set it on AWB.
Sep 07, 2009 | Fuji FinePix S1000FD Digital Camera
What does the yello camera with the yello
I have an S1000fd and to get rid of the yellow camera icon with the exclamation mark next to it I pushed the button on the side of the flash to pop the flash up. Its a low light level indicator basically.
Aug 10, 2009 | Fuji FinePix S1000FD Digital Camera
Yellowish picture & blackish face
look kindly set ur jog dial to AUTO if problem persists then it might be a CCD FAILURE it happens in that , Yellowish Pinkish or Redish Tones , Streaks , Blank pics , Over Exposed pics all are syptoms are of CCD Failure !
if after the AUTO settings it persist then contact FUJIFILM it is a known problem in thousands of cameras they will do it FREE REPAIRS even if u are out of warranty dont worry just call them see a link for this problem this problem is active in new models as well
KINDLY RATE ME WELL !
http://www.imaging-resource.com/badccds.html
May 28, 2009 | Fuji FinePix S1000FD Digital Camera
My FINEPIX s1000fd fujifilm camera displays zoom error! in red and won't take pictures please help. We put new batteries in and think I have all the settings right thanks ellen Focus Error and lens will...
Apr 02, 2009 | Fuji FinePix S1000FD Digital Camera
Flash pops up but does not flash
Turning the Flash Off and On: 1. With the camera in any user set, repeatedly press the Flash/ISO button on the lens barrel until the flash cancel icon (a lightning bolt in a circle with a slash through it) is displayed on the control panel and screen. 2. When finished, to return to the default setting, press the Flash/ISO button until AUTO and the lightning bolt icon are displayed on the control panel and no flash icon is displayed on the screen. If it still doesnt help: 1. Check that batteries are fresh. 2. Check that camera hasn't been set for no-flash mode. 3. Give the flash time to charge before pressing shutter.
Sep 07, 2005 | Nikon Coolpix 5700 Digital Camera
Fuji FinePix S1000FD Digital Camera Logo
389 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
