Question about Samsung SGH-G600 Cellular Phone
My cd rom is opening but on clicking any folder it is showing "empty folder".this is not a case with one of the cd but for all the cds. please help me to solve this problem...... and on installing anythingform cd drive it show "not valid win32"
    President:
  • 216 Answers
Use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Posted on Dec 30, 2009
My cd rom drive plays cds rips cds reads and does cd rom programs but will not let me burn cds any more..... i was able to burn cds just fine before???? please any help?
Have you tried reseating the CD rom;verify all the connectors are securely fastened. What type of Dell is this; a tower, desktop, or laptop? If you know how to open the case then proceed with reseating as follows:
First power down the system
After opening the case
locate the CDROM
If this is a new system it is probably connected using a SATA connector (black cable with a blue connector and power connector.)
At the back of the remove each connector then reconnect the cable
The SATA or Parrellel cable has a connector at both ends so trace the cable and re-seat the connector on the motherboard as well.
close the case
boot the system back up
test the cdrom
Aug 01, 2011 | Dell Computers & Internet
The computer is detecting the CD rom but the cd rom is not detecting or reading any CDs
The laser is probably burned out or the spindle motor isn't turning.
With the price of these units, I'd just replace it.
There's not much you can do to fix either problem anyway.
A CD ROM (hard to find, but some places still carry them) can be had for $5 or $10.
For just a bit more, you could get a DVD burner.
Mar 17, 2011 | Sony (CDU701) Internal 32x CD-ROM Drive
My SONY CD-RW CRX320EE reads CDs but it doesnot read dvds correctly and it doest write on Cd when i want to make cd ,it makes it but the cd doesnot open. the dvds donot open but somtimes open. please help...
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 07, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My Acer Aspire 5810TZ won't read DVDs or CDs, it says the device is not there. where do i download a replacement?
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 07, 2011 | Acer Computers & Internet
Unable to read the cds & dvd s are opened show the folders but not open the files
control panel,folder options select view scroll down to hidden files and folders tick in show hidden files and folders
or in the folder options place a tick in the single click to open circlce/box
hope this helps
Dec 03, 2010 | Computers & Internet
My pc wont open football manager 2009 disk
click on the diskdrive that fm is in once to get the pop up menu and click on open auto play and then click onto open folder and in that folder there should be the application to install football manager 09
Jul 04, 2009 | Video Game Consoles & Games
DVD/RW IS NOT WORKING CODE 39
I was fixing a computer the other day and ran across the following error in Device Manager on the CD-ROM drive.
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Because of this error, the drive did not show up in My Computer and the customer was unable to burn CDs or read any CDs.
I uninstalled the drive from Device Manager, rebooted the computer, and the problem remained, so obviously it appeared to be a registry issue that I would have to solve. If you are receiving this Code 39 error and your CD or DVD drive is missing and has a yellow exclamation mark in Device Manager, I hope this information is useful.
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot
your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
If you found this helpful , please rate my solution below :D
Kind Regards
1234s282
Jul 03, 2009 | Acer Computers & Internet
Diablo 2 problem
try clicking on the auto-run file in the CDs folder. if still you cant get it to auto-run or start installing clean the cd and make sure you have the install disc in not the play disc or the cinematic disc
Dec 11, 2008 | Vivendi Universal Diablo Battlechest II...
Mp3 cds
Insert blank CD into cd-rom, open my computer, open folder containing mp3 files, Drag the mp3 files to the drive letter of the cd-rom drive, double-click drive letter - write files to disc
Mar 11, 2008 | iLO (2 GB) MP3 Player
CD-RW/DVD-ROM can not read and CD or DVD
yes..it's most likely kaput. I have a tecra, and I'm on my second CD/DVD replacement. They are easy to find and replace(one screw underneath, and just slide em out)..
Feb 17, 2008 | Toshiba Tecra 9100 Notebook
Samsung SGH-G600 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
