Question about Xerox DocuColor 12 Color Copier
CMYK dot problem
I have the cmyk problem. I changed the drum and developer also. Eventhough the problem appears after 200 prints. My room temperature also 20. I expect the solution of this problem. thaniking you
    Champion:
  • 241 Answers
Can be solves by changing whole drum unit because problem with bias grid (black strip on chager)
Posted on Mar 29, 2010
Grievance
Do the colour prints when printing RGB look all right?
If so, the printer is working.
What sort of CMYK are you trying to print? CMYK EPS prints, maybe?
If so, the the fault is one of not using the correct software; the printer is working, it is just not interpreting the encapsulated PostScript to reproduce a CMYK image. Use different software capable of reading CMYK EPS files. Photoshop is one such piece of software.
Dec 12, 2013 | Office Equipment & Supplies
We have a sharp mx3501n printer. Whenever I print from Photoshop CS2 the prints are horrible. Any suggestions for color profiles/settings that might make this better. Should I be using a CMYK file in...
Definately CMYK so you can see which colors are out of gamut. If copies are lousy too, then you might have old supplies in the machine. In service sim mode (type # * C *) go to 64-5 and print the test charts directly from the print engine. You should get one greyscale and one color page. If those look bad, then you need a supply change (drum, developer, or belts). In the driver under Printing preferences you have the option to set color schemes until you find one that works. If you still have trouble, get a new driver from www.sharpusa.com, past that a firmware flash may be necessary.
Jan 25, 2011 | Sharp MX-3501N All-In-One Printer
I replaced toner and now light print
you need to replace the K pcu and if the unit has 60K prints all of the consumables need replacing CMYK drums CMYK Developers and the imaging transfer belt and fuser unit
Jul 08, 2009 | Ricoh Aficio CL3500N Laser Printer
Why Recieve Bad quality for picture CMYK mode in umax 2100 XL?
What makes you think the scan is bad quality? How are you proofing it. Did you print in on a printing press or other CMYK device? The CMYK colorspace cannot be displayed on monitors without the program you are using converting it to RGB for display. Are you reading the actual CMYK values with the densitometer?
In my experience, with cheap scanners (under $75,000) it's best to scan to RGB and let Photoshop do the CMYK conversion. Just be sure to use the correct profile for your output intent.
Feb 05, 2009 | Umax BINUSCAN - PhotoPerfect CMYK & RGB...
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
CMYK spots on print
- Please check properly if they have Leek?
- Try to clean the Glass inside and out-side the machine
Sep 20, 2008 | Xerox DocuColor 12 Color Copier
CMYK spots on print
each dots comes .5mm gape in one by one at different places pls check and replace a new drum.
Jul 27, 2008 | Xerox DocuColor 12 Color Copier
3100 Dell Printer - Printing CMYK DOTS TWICE ON EVERY PRINT
We had a Dell Engineer come out for this prob and it basically involved replacing every working part inside it until it worked! :-(
He said he believed that it might have been toner leaking out, but I don't believe that because of the precision of the dots on every printout.
I hope urs is in warranty!
Jun 20, 2008 | Dell 3100cn Laser Printer
Cmyk dots on the print
There are several causes of those.
So go to Xerox.com
Click "support and drives"
then in the product name box, Type DC12
Then any line click support
IN the search box type "spots" and read the relevant solution.
May 05, 2008 | Xerox DocuColor 12 Printer
Printing CMYK dots twice on every print
Hi, As it's printing two little strips (like a 1/4inch) of CMYK dots (one of each color all you need to check the toner cartridge drum, try to wipe the toner drum with a damp cloth on each color cartridge. Secondly check the fuser assembly drum if it has any mark on the drum, try to use a mild isopropyle alchohol to wipe the dirt mark them try printing. this will resolve the issue. if still issue persists then change the color cartridge one by one. This will definitely resolve the issue.
Oct 05, 2007 | Dell 3100cn Laser Printer
Xerox DocuColor 12 Color Copier Logo
103 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
