Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Kitchenaid KUDP01 not cleaning dishes
The kitchen aide dishwasher is simply not cleaning dishes. We had a new motor assembly put on about a year ago and now its doing the same thing. The warranty is out so I basically just need to know what part to replace. It appears there is not enough 'pressure' in the water to clean dishes, it puts out water but there is no pressure at all. Nothing gets clean on the top rack, the bottom is so so and the place that holds soap, seldom all the soap is out, it leaves soap in the trey, so there is not enough pressure inside the dishwasher when washing to even hit the door hard enough to get the soap out of dispenser.
Is there a filter in the dishwasher that needs to be changed out?
Posted on Jul 09, 2009
Remove the accumulator assembly and check the chopper to see whether it's clogged or damaged.
Posted on Jul 08, 2009
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
Leaves a white soap residue over the dishes, the dishes are scratched. New Kitchen Aid model KUDS50FVSS4 just purchased one month ago and it's performance was not as good as my old ( 15 years) GE. I have...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101;'
Apr 25, 2011 | KitchenAid KUDS50FVSS Builtin Dishwasher
Dishes in the upper rack no longer get cleaned. I've been using this dishwasher since 2004 (purchased new), and have not changed the way I loaded the dishes or the detergent. I called the Kitchen Aid help...
It may be full of crud under screen. Remove lower spray arm, tower up to top, covers and you will see where the entrance to the impeller is full of stuff.
Oct 28, 2010 | KitchenAid Dishwashers
Our kitchen aid dishwasher is about 7 years old, recently it has begun making a high pitched whine while the wash cycle is running. The dishes are still clean, but the noise is new and annoying not to...
Sounds like it could be the bearing in the wash motor. If the sound is only present when you can hear water being thrown around then this would confirm it. Not sure about spares availability on a 7yr old machine though
Jan 18, 2018 | KitchenAid 24 in. KUDI01FLSS Stainless...
TOP SPIN ARM NOT SPINNING TO CLEAN TOP RACK OF MY KITCHEN AID DISHWASHER. IT IS ONLY 1 1/2 YEARS OLD AND MY TOP TACK IS SUDDENLY NOT CLEANING
Hi.
First ensure that the arm is not getting stuck, and check that the orifices are free.
When the top arm is not spinning you may need to replace pump and motor assembly. First it is good looking for blockage in pump hose.
If the appliance is less than two year old, then it may be covered by limited warranty. Call Kitchenaid at the number listed in the owners manual to verify your warranty status.
Regards.
Nov 20, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
My Kitchen Aid KUDI01FLBL3 is not cleaning my
Most likely there is debris at the pump impeller. This model has a problem with debris and grease accumulation at the pump inlet. I have no idea how it gets past the screen but it does. Remove the transfer tube on the back wall, the lower sprayer, and screen assembly. Clean out the debris and reverse installation.
Sep 16, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
KITCHENAID dishwasher will not dry the dishes
kitchen aid mod kud101dl does not clean dishes well. lot of scum on door.
Feb 26, 2009 | KitchenAid Dishwashers
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Kitchen aid dish washer about 5 years old
Yes I called a service man . Thankyou
May 30, 2008 | KitchenAid Dishwashers
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
563 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
