Question about Taylor 5757 Digital Glass Body Fat Scale
Err 4 when I turn m scale on it starts at 6.4 pounds instead of at zero, so I figure I can still weigh mysef and subtract the difference. But I can't even get a weigh, instead Error 4 pops up ad I don't know what that means as I've lost my manual. Help please? Is it a battery thing? I know Error 3 is whn you arn't barefoot or step off before the BF can be annalyzed, but I don't know what error 4 means.
  • 3 Answers
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Posted on Oct 17, 2009
I have a Penn Scale CM 101. On the net weight it registers -1.23. WE can not get it to zero out. Any suggestions?
1 Have the scale turned off
2 Turn it back on
3 While it’s counting down press the Tare button
4. Asks for passcode enter 0000
5 Keep pressing Tare until it says Load 30 pounds
6 load the thirty pounds
7 turn scale off
8 remove 30 lbs
9 turn back on
I hope this works for you as well
Sep 16, 2017 | The Health & Beauty
Is there a way to calibrate without 3-50 pound weights?
water weighs 10lb to the gallon ( engilish measurement-calculate amount for us gallon)
so get your self a jug and place it on the scales empty adjust the scales to zero
fill the jug with a measured amount of water (example 1 pint will weigh 1.25lbs
then set the scales to the reading of 1.25lbs
to check the scales accuracy you can add extra water to the jug (say 4 pints ) and the scale should read 5lb
Jul 25, 2015 | Office Equipment & Supplies
Salter scales weighing more than double the weight
Sounds silly but check the scales for a Kilogram or Pounds switch. its usually under the scales and is a sliding switch. It should tell you on the display if you are weighing in pounds or kilos.
Sep 15, 2014 | Health & Beauty
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
ERr
Are you talking 31 "Stone"? If so, I believe that comes out to 434lbs. You are lucky if your scales can read that high. For testing purposes, remove your shoes or more if you think your right at the upper limit. Or let a slightly lighter friend try it. I assume your talking "Stone" as used in the UK. Are you from there? (I,m in the US, in Florida.) Also, there should be a switch on the bottom of the scale (upper left corner) allowing you to switch between lbs, st and kg. You can try that as well, although the limit should be basically identical. If you tell me more, I can help you more.
(By the way, I weigh 197 lbs right now, that's 14 stone.)
May 19, 2013 | Health & Beauty
Scales are getting a Err 1 message, installed new batteries, need to reset them some how. They will not zero themselves out
My scale was fine the other day. I weighed myself earlier in the day. I tried to weigh myself later in the day and the scale started reading ERR1. I called Taylor and they had me try to "reset" the scale twice. It did not work.
The steps for resetting it are:
Turn the scale over
Remove the batteries for at least 10 seconds
With the scale on it's side (even though you aren't supposed to put the scale on it's side, carefully insert the batteries and put the back on the scale
Slowly return the scale to a flat hard surface
Step on the scale after about 10 seconds of it being back in position
If the scale still jumps with crazy numbers and reads ERR1 try to reset the scale again being very careful when the scale is on it's side
If this does not correct the problem then the scale will need to be returned to the manufacturer, to the address on the label on the bottom of the scale
I was told you could put the scale in any box and ship it to them the cheapest way possible but be sure to keep the batteries with you
If you are still under the year warranty they will send you out a new scale in 4-6 weeks
I was not happy that my scale was purchased on 11/14/09 and it died on 02/12/10. Luckily I knew where my receipt was. I pulled it out and noticed 02/12/10 was the last date to make returns to Target for that transaction. I was able to go and return my scale to the store because it was in the 90-day window that I had purchased it.
I was told that the reason the scale was doing this was either an delayed electrical interference that may have occurred during. The only other reason I was given was an OVERLOAD. Well, I seriously doubt an overload was my issue. First of all I was the only person at home that day so nobody else stood on the scale. I had used it earlier in the day and it was accurate. I am 5'6" and 139 lbs. so I seriously doubt it was OVERLOAD unless someone isn't telling me something and I need to lose some serious weight.
Anyway, I hope this helps. I wasted a lot of time trying to figure it out that day. Now I have my new receipt and if this happens again I will go get my new scale just as I did this time. I thought a 4-6 week wait for a replacement scale was insane. Kudos to Target for taking the scale back without a box or instructions on the last day I was able to make a return.
Feb 09, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Taylor 5757 Digital Glass Body Fat Scale Logo
836 people viewed this question
Top Taylor Health & Beauty Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
